Help small dump trailer design: safe?
   / Help small dump trailer design: safe? #1
oldboyscout
ne PA
Kubota B2620
I need to build a small dump trailer. I'm thinking of 3 foot wide frame with 4 1/2' wide box over it. The box would be over the wheels which are 26 inch diameter. Will the center of gravity be too high?
Sure trac makes a trailer very similar to this but it's on smaller wheels. Unfortunately the smaller wheels cannot take brakes, which I really want.
   / Help small dump trailer design: safe? #2
This is for both on road and off road. The tires are the problem. The Suretrac has the small diameter wide tires, but they're so small that brakes won't fit. The smallest tires that will work with brakes are 6" larger diameter, but the same width, 205.
I could use something like that, except it can't have brakes.
   / Help small dump trailer design: safe? #6
Why can't it have brakes? couldn't it have surge brakes?
smallest wheels that will take brakes is 14"
   / Help small dump trailer design: safe? #8
What size wheels are they?
basically want to build this:
Sure Trac |
but on 26" tires instead of 20". so I can add brakes. I don't know if the center of gravity will be too high.
   / Help small dump trailer design: safe? #10
Can you make your bed sit in between the wheels but extend over the top of the like most ATV trailers?
Or put your wheels outside the bed?
Or use drop down axles?
2015 Ram 1500 4x4 Crew Cab Pickup Truck (A48081)
2015 Ram 1500 4x4...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
UNUSED Woven Landscape Fabric Rolls (A50860)
UNUSED Woven...
2014 Ford Escape S SUV (A48082)
2014 Ford Escape S...
2009 IC Corporation PB105 School Bus (A48081)
2009 IC...
Kopalift 2,000lbs Electric Walkie Stacker Forklift (A49346)
Kopalift 2,000lbs...
