Help sizing and choosing a tractor, JD vs. Kubota
   / Help sizing and choosing a tractor, JD vs. Kubota #11
</font><font color="blue" class="small">( you often step on one brake pedal with the steering wheel turned, excellerate, and spin the tractor on a dime )</font>
With the B7800's pedals this can be done with toe on the brake pedal and heel on the speed control pedal.
Well, I spent a few weeks looking and contemplating, and I think I'm going to get the JD 3720 (which replaces the 4410) if the dealers price seems right. I decided on the extra power of the 3720 over (say) the 3120 because it adds 20% to my spending for a nearly 50% increase in power, and some of the attachments I'm considering recomend a minimum 30HP at the PTO which only the 3520 and 3720 have.
I have a few remaining questions I hope the group can help with ...
1. I'm getting the 61" bucket on the FEL which can take a replacable cutting edge ($100) - buying the heavy duty bucket is only $100 more, so there doesn't seem a reason not to, unless it is a complete waste - any opinions on whether the regular bucket is adequate, especially given I plan to use the replacable edges?
2. I'm debating whether to get the 72" mower deck - for about the same price I can buy a separate L120 garden tractor which will be dedicated to grass cutting - I only get a 48" deck on the L120 instead of 72" on the 3720, but the mower will be much lighter (less compaction) and I won't ever have to take it on/off - for a bit more money I might buy a zero turn type mower instead, and have both a bigger deck and lighter weight, so that is another option. Opinions?
3. I'm considering a 44 bushel Trac-Vac to pick up grass and (especially) leaves, but I've heard from one landscapper that they can clog a lot and are not worth it - one friend recomended I buy a $250 Lawn Sweeper instead, which won't re-mulch it but will pick up debris - any opinions on how lawn vacuems work and the best way to deal with large amounts of leaves and grass?
4. Lastly, I think I may get the turf tires and then add chains for traction when I need them, instead of R4's - I'm thinking this gives me the best of both without having to swap tires - opinions?
Many many thanks - you all have been /forums/images/graemlins/cool.gif
   / Help sizing and choosing a tractor, JD vs. Kubota #13
As far as the bucket goes, I guess that depends on what you'll be doing with it. If you think you'll end up banging it around a lot and possibly bending the lighter bucket, I'd opt for the heavy bucket (which is what we have).
We have the R4 tires and I don't think I'd go with anything less aggressive than those for our situation (hills/inclines). Personally, I'm a little lazy when it comes to adding things to temporarily improve something and then removing it again when not needed. I just can't see myself out there fooling with chains. I know I'd be cursing and wondering why the heck I didn't just get better tires in the first place. But that's just me /forums/images/graemlins/wink.gif If you think you might find yourself in that situation later, get the R4's.
Good luck. The 3720 looks like lots of fun /forums/images/graemlins/smile.gif
   / Help sizing and choosing a tractor, JD vs. Kubota #14
If you are buying a dedicated mower, get the R4's. There are many times I wish I had R1's. Do you have any soft areas of mud on your property? This tractor is not that heavy and if you wait til your lawn dries, R4's shouldn't be a problem. Unless you are a lawn perfectionist.
   / Help sizing and choosing a tractor, JD vs. Kubota #15
Back to your backhoe debate for a moment, Homeboy. I am a recent purchaser of a JD 4410 with a 48 backhoe. I simply love it. The ease of installation and removal is nothing short of amazing. I can't imagine that they went backwards with 448.
One thing I would consider in your shoes is to look at a 4410 if you can still find one. I sat on and drove both the 3520 and 4410 and felt more comfortable with the 4410 --- it was also quite a bit less expensive since it has been replaced.
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
Honda utv cart (A56859)
Honda utv cart...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
