Help! Several issues with my i believe 1994 B7100hst -d 4wd
   / Help! Several issues with my i believe 1994 B7100hst -d 4wd #11
I don't know what year you have and if it is different than mine, but you don't shut it off with the decompression knob. That's for starting when very cold only.
The shutoff lever is under the right side of the dash. It should be yellow and it shuts off the fuel.
So it turns out that the previous owner took the PTO lever off and put it on the shifter and just didn't have a PTO lever since he didn't use it because of this the PTO lever could not move up high enough because it was too long to allow it to be put into low gear once I obtain the correct lever and switch then back it goes into low perfectly now. The shut-off I've learned is done through the throttle by throttling all the way down and holding it all the way down there is a spring that returns it if you don't hold it it was out of adjustment once I just did it and now shut off just by holding it and when it's done I let off in then the tractor shut off. So now my only issue is that the tractor will automatically go forward when put into gear without pressing accelerator which is a pain in the butt when you're trying to go in reverse I've searched around trying to figure out how to adjust this and can't seem to figure it out does anyone have any pointers on this. So far for $1,000 this tractor was a great Buy it runs and drives well starts every time as a few leaks here and there I smoked a tiny bit when under heavy load but overall it's functions very well anyway if anyone can help I greatly appreciate it thank you
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
PALLET OF PICK BUMPERS (A50854)
PALLET OF PICK...
2020 KUBOTA RTV...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
1998 CATERPILLAR D5M PIPE LAYER (A50854)
1998 CATERPILLAR...
