Hiawassee Longhorn
Help so my b7100 has a few issues. First as soon as its put in gear it trys to go forward just a little before any forward or reverse is applied. Second low gear used to work the first day i had it but while trying to figure out all thw functions it now grinds and pops out as soon as forward or reverse is applied high gear works fine. Finally shutting it down when i try to shut it off throttling down as far as it goes and turning key off will not shut it off the decompression knob is not present so no using that even if I wanted to (though i know it's not a good to use it). So the method the guy i bought it from was to throttle down turn off the key and then put it into gear and then apply forward or reverse to essentially pop the clutch (im sure this is not good for it at all) anyway if you have any ideas on any of this please let me know. Thanks
