Help! Sensor error after washing
/ Help! Sensor error after washing #1
Digdug5240
Kubota L5240
I've got an "ERROR-84" "ACCEL NG" on my L5240 after washing it. The owner's manual says the it is "Sensor for engine throttle is in trouble".
All I really need to know is where this sensor is. I think it is a spring loaded sensor that sets on top of the throttle but I'm not 100% sure.
Thanks for any help.
Doug
/ Help! Sensor error after washing #2
Doug
It sits on top of the throttle control on the injection pump.:thumbsup:
/ Help! Sensor error after washing #3
Doug
If you have a salamander heater try to dry the tractor out with it for an hour with the air flow from the right side to under the motor to dry it out and this should work OK as the heat will travel upward under the engine.
Thanks to leonz and kuboman for the help. The tractor is running but no moving now. I started a different post for this problem.
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
