Help selecting steel for trailer tongue
   / Help selecting steel for trailer tongue #1
Efis
Northwest Colorado
Allmand 35D(tlb535),Gravely pro 16,5665
Hello. I have a 8.5 foot tilt bed snowmobile trailer I use to haul whitewater rafts. The present tongue is 3x3 1/8inch wall tubing total length is 7 feet long ,4 feet under the trailer and 3 feet extends forward of the deck to the coupler. I want to replace with 10 foot tongue to allow extending the deck by 2 feet, putting the load more forward for more tongue weight and allowing space for a post with winch. I figure total load between 1000--1500 lbs. Wondering if I can stick with same material or if I should consider going up to 3x4 x 1/8. Thanks for any thoughts!
   / Help selecting steel for trailer tongue #2
Can you section it and sleeve it?
I have a tongue that is adjustable... the solid part slips inside the tubular part and a removable pin holds it into place.
   / Help selecting steel for trailer tongue #3
I'd go 3/16" wall thickness on the 3x4 tube. I want a trailer tongue to be overbuilt. Broken trailer tongues while going down the highway = bad news.
   / Help selecting steel for trailer tongue #4
I'd go 3x3 or 3x4 with 1/4 or 3/8 wall.
   / Help selecting steel for trailer tongue #5
:thumbsup:
   / Help selecting steel for trailer tongue #6
I'm all for doing it yourself, but you are opening yourself up for a can of worms if you ever get in an accident or something breaks. Have you looked into trading in or selling the current trailer and getting one that suits your needs? That way you aint liable if the thing fails? That and not knowing your welding skills and equipment, I am hesitant to advise.
   / Help selecting steel for trailer tongue #7
I'd hate to sell a homemade trailer. You could still be liable. The local metal fabrication shop won't touch a trailer or fuel tank with a 15 foot pole.
   / Help selecting steel for trailer tongue #8
We have an outfit here the modifies trailers, builds custom hitches and flatbeds... they have been in business 40 years... two brothers... so far they have a stellar record.
Sometimes they don't get the job because they won't cut corners.
They also do trailer collision repairs.
Most of my trailers are home made or custom made... the custom made shop that closed after 70 years... they also built bridges and lots of custom stuff for the local zoos...
   / Help selecting steel for trailer tongue #9
It's strange how stuff like this is so regional. I have seen so many homemade trailers made from things like trailer house frames or used pipe that I've lost count. I've even made a few myself. Homemade trailers are very common in the rural areas I have lived. I never once gave it the concern I see in this thread.
Heck Oklahoma doesn't even tag trailers and it was easy to get a tag for a homemade trailer here in Nebraska. To be perfectly honest I have looked at many manufactured trailers and the welding was always pretty crappy. Just because they crank them out of a manufacturing line doesn't mean the guy doing the welding is doing a great job.
I would not even think twice about swapping out a tongue on a light duty trailer like this.
   / Help selecting steel for trailer tongue #10
Depending on the skill of the person building it, there is nothing wrong with a home made trailer. Some are better than factory built trailers. 3/16" or 1/4" wall tubing will add a lot of strength. 3/8" is way overkill and a whole lot heavier. Another option is to add an A frame hitch or long or braces from the tongue to the trailer corners. I'm not sure what your trailer has now.
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A53472)
Heavy-Duty...
SCAN TO RECEIVE TEXT UPDATES (A51246)
SCAN TO RECEIVE...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
2012 CATERPILLAR 316EL EXCAVATOR (A51246)
2012 CATERPILLAR...
2023 John Deere 6120E MFWD Tractor (A53342)
2023 John Deere...
