HELP - Rewiring 7 pin socket on JD 2040S
   / HELP - Rewiring 7 pin socket on JD 2040S #1
hward
UK
JD2040S
I've got a John Deere 2040S and I managed to completely bust the part where I plug the 7 pin socket in for trailer lights. I completely smashed it so I can't tell which wires go into which pins on the new one. The problem is it's the old 5 wire system to go into the 7 pin socket and the wires are totally different colours to what they are now. Does anyone know which are which?
The colours I have are - black/green, black/white, grey/black, grey/red, black/red
I'm fairly sure that the black/green wire in the right hand indicator as it was still attached to a piece of the old plastic when I unscrewed it, but I've not a clue about the others.
   / HELP - Rewiring 7 pin socket on JD 2040S #2
If you can't find out on here........ Back up to the trailer and ground it to the tractor. With a long jumper wire, start poking around until the desired bulb lights up. Wright it down on paper and keep going until all the pins have been identified.
   / HELP - Rewiring 7 pin socket on JD 2040S #3
What I could find was that the black/green is RH, black/white is LH. The other colors I haven't found anything conclusive, but gray/red should be +, gray/black - and black/red stop, if you haven't already deduced.
Thank you both, I managed to fix it today. In addition to the indicators - black/red was earth, and grey/red and black/grey were the tail lights. And it seems that there isn't a wire from the tractor for stop which seems odd, but the brake lights have never worked on the tractor or the trailer lighting board since I got it.
   / HELP - Rewiring 7 pin socket on JD 2040S #5
U can work it the other way
1....left ind
2...reserve
3...earth
4...right ind
5 and7 ..parks
6...brakes
2012 Mack CXU613 Sleeper Truck, VIN # 1M1AW07Y3CM018973 (A51572)
2012 Mack CXU613...
SELLICK S80T4E-4PS ROUGHT TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
