HELP! Replacement tire needed!
   / HELP! Replacement tire needed! #1
Cord
Richfield, Wi
Resident Architect
I blew one of my front tires yesterday and I'm having a tough time finding it's replacement. The tire is a 4.00x10. The tire is on the front of a 4wd tractor, so I need to stick close to the 18" diameter. Currently there is a bar tire on, so I'd use a bar tire or a agressive turf tire in a comparable size. I do know that a 4"x12" trailer rim will fit the hub, but I'm still having trouble with the diameter. Any thoughts?
   / HELP! Replacement tire needed! #3
Are you sure it is a 4.00x10" tire?? I looked in the TSC, Northern Tool and Agri-supply catalogs and found no listings at all. Could it be a 4.10 or 4.20 tire instead of a 4.00? Is the 10 on it the ply rating or the rim diameter?
   / HELP! Replacement tire needed! #4
Definetly a 4x10. The 10 is the rim size, which apparently is part of the problem.
   / HELP! Replacement tire needed! #7
You might try Carlisle Tires They seem to have a great assortment of tires. Several in the 4.0 X 10 , 12, 15 range. I'm not sure if they have the exact size/diameter you need.
   / HELP! Replacement tire needed! #8
Best I can tell, Carlisle does not carry a 4x10 ag tire. I do have a couple of their 18x8.5-10 tires on order. I'm hoping these will fit a new pair of rims for turf usage. I despiratly need a pair of tires for playing in the dirt. I'd like to use ATV mud tires, but it's very hard to find them in less than a 22" diameter.
40' CONTAINER (A51244)
2000 New Holland TN65 Tractor with Loader (A51573)
2000 New Holland...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
