HELP! Replacement tire needed!
   / HELP! Replacement tire needed! #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
I blew one of my front tires yesterday and I'm having a tough time finding it's replacement. The tire is a 4.00x10. The tire is on the front of a 4wd tractor, so I need to stick close to the 18" diameter. Currently there is a bar tire on, so I'd use a bar tire or a agressive turf tire in a comparable size. I do know that a 4"x12" trailer rim will fit the hub, but I'm still having trouble with the diameter. Any thoughts?
   / HELP! Replacement tire needed! #3
Are you sure it is a 4.00x10" tire?? I looked in the TSC, Northern Tool and Agri-supply catalogs and found no listings at all. Could it be a 4.10 or 4.20 tire instead of a 4.00? Is the 10 on it the ply rating or the rim diameter?
   / HELP! Replacement tire needed! #4
Definetly a 4x10. The 10 is the rim size, which apparently is part of the problem.
   / HELP! Replacement tire needed! #7
You might try Carlisle Tires They seem to have a great assortment of tires. Several in the 4.0 X 10 , 12, 15 range. I'm not sure if they have the exact size/diameter you need.
   / HELP! Replacement tire needed! #8
Best I can tell, Carlisle does not carry a 4x10 ag tire. I do have a couple of their 18x8.5-10 tires on order. I'm hoping these will fit a new pair of rims for turf usage. I despiratly need a pair of tires for playing in the dirt. I'd like to use ATV mud tires, but it's very hard to find them in less than a 22" diameter.
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
KUHN GMD-310-HD LOT NUMBER 38 (A53084)
KUHN GMD-310-HD...
More info coming soon! (A50322)
More info coming...
