Help removing gear box Landpride RCR1860
   / Help removing gear box Landpride RCR1860 #1
Vineyahd
Chilmark, MA
kubota mx5100
Well the gear box needs to be replaced but the blade drive / dishpan assembly is stuck to the gearbox shaft. Any ideas as to how I can remove the bloody thing?
   / Help removing gear box Landpride RCR1860 #2
I have a different brand, but I'm assuming it's a tapered shaft like mine. The way that safer than I the way I used would be to unbolt the gearbox, flip it over, and block it up so that it's resting on the platform instead of the gearbox. Put the nut on part of the way and take a hammer to it. I think some heat on the dishpan around the shaft would help quite a bit as well. Obviously there are a lot of safety considerations here that I've not mentioned.
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2020 COLOMBO TM LOT NUMBER 215 (A53084)
2020 COLOMBO TM...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2021 John Deere C12R Corn Head (A53342)
2021 John Deere...
