HELP! PTO is stuck on!
/ HELP! PTO is stuck on! #1
Anonymous Poster
Epic Contributor
'77 Ford 4000 has rear PTO stuck on. On/off lever moves freely but won't turn it off. Seems to have happened at about the same time shear pin snapped on McKee snowblower after pushing into icy bank. Not sure if related or just a coincidence. Tractor is a loaner I REALLY need to make right again ASAP. Any thoughts?
/ HELP! PTO is stuck on! #2
did you follow the linkage all the way down to make sure it didn't come apart? See if the free movement goes all the way into the housing.
murph
/ HELP! PTO is stuck on! #3
If it is a 4000 with independent PTO it will have to be split between the transmission and rear axle. Several scenarios are possible. The good news is that any parts required are still available. The joys of borrowing!
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2016 VOLVO EC250EL EXCAVATOR (A64279)
2016 VOLVO EC250EL...
