HELP: pto disconnect
/ HELP: pto disconnect #22
I can only assume that the push-button worked TOO well , therefore WE ( safety police ) must make it much more difficult. I tried too explain my plight to upper management ( Wife ) that obviously I need a tractor for each implement so I didn't have to go through ALL this stress of fighting the PTO hookup. SHE just doesn't understand !! I then tried the ( well YOU have shoes and purses for each outfit ) :confused:HUH???? THAT DIDN'T GO SO WELL FOR ME !!!! guess I'll Have to figure this out :D
/ HELP: pto disconnect #23
I hate the damned things. I think someone was going overboard with safety. To get hung up in the PTO push button style you would really have to go out of your way or be really stupid, or both.
I dunno about that. My bush-hog has the pushbutton on it and it was a real PITA to attach it to my LK3054...there wasn't enough room inside the PTO shaft shield to get my (rather large) hands in. Finally said screw it & took the shield off. Just have to remember to be careful (I always shut engine off when taking implements on/off).
/ HELP: pto disconnect #24
All I can add is that it used to be somewhat of a struggle to connect PTO shafts on my old Kubota tractor. The flip up PTO shield on the new Kioti makes all the difference in the world.
/ HELP: pto disconnect #25
The push button was an area that could catch loose clothing... and the results are not pretty.
The first time I hooked up my pto, I removed my pto shield and have never thought about putting it back on... and this was with one of kubota's worst tractors, the L2800. My pto would not always disengage (learned that the hard way by started the tractor with the pto OFF - let out the clutch and the tiller that was hooked up on the 3ph proceeded to dig a hole in my barn - not a happy camper).
I would hate to have a PTO that didn't spin freely when turned off. :confused2:
2019 KAUFMAN 46' STEP DECK TRAILER (A64280)
2019 KAUFMAN 46'...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2019 CATERPILLAR 259D SKID STEER (A64279)
2019 CATERPILLAR...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
