Help! Power loss 4500z
/ Help! Power loss 4500z #1
Dennisonross
2020 4500z
I have a 2020 4500z(covid model possibly?) that I bought from a dealer with around 150 hours, I’ve run a 2014 4500z for 8-9 years at a school for mow and snow, ran like a champ, never a power issue stayed around 3600rpm no matter what I ran and never seemed to bog. Loved it so bought one for home. Had mine 2 years and never ran like the work unit I was used to. will idle at start maybe 3500 but warms up and drops to 3300 and only running a 60” mower will drop to 3100, snow blowing at school will launch snow 45’, with mine it seems to barely throw it 25. High speed up 1-2 degrees drops to 9.1-9.2 mph. Dealer is great but missing the issue somewhere. I thought fuel so dumped fuel ran 93 through it with a bottle of sea foam changed filter twice, no change, dealer messed with throttle cable, made no difference that I can tell, took it back he messed with throttle again said it was normal, Only other maybe indicator, it often tries to die on startup, choke—fires—idles for 2 seconds-sputter/cuts out, cut,cut,cut 3 seconds idles. Any ideas
/ Help! Power loss 4500z #2
For me first guess, dirty carb. Second plugs, then ignition coil
/ Help! Power loss 4500z #3
Since your machine "never ran like the work unit," I suspect the valves are out of adjustment.
I adjusted the valves at about 300 hours and it ran like a different machine after.
Thank you for the response. I’ll start small and work out. Let you know what I find.
  • Good Post
Reactions: D&D
UNUSED X-STAR GRAVEL LEVELER (A60430)
UNUSED X-STAR...
2014 American Signal Solar Towable Message Board (A59228)
2014 American...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
2014 CATERPILLAR 930K WHEEL LOADER (A60429)
2014 CATERPILLAR...
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
KUBOTA L3901D TRACTOR (A59823)
KUBOTA L3901D...
