Help please, 09 TYM T330 hydrostat with ratcheting sound from the rear.
   / Help please, 09 TYM T330 hydrostat with ratcheting sound from the rear. #1
Vmax540
Clarion PA.
2009 TYM T330
Hello, I have a 2009 TYM T330 with a LT300H F.E.L and backhoe and tires are loaded. With front bucket edge vertically down to back drag and level a ground pile of hard clay and rock in low range and all of a sudden I hear this metal like gear ratcheting/skipping sound from the rear. Tractor still moves in all ranges fwd/reverse without any sound. It is only when under fairly heavy load will it ratchet or skip. On another note as I have mentioned before the front tires spin in or out of 4wd. This sounds expensive... Thanks for any help.
   / Help please, 09 TYM T330 hydrostat with ratcheting sound from the rear. #2
I would start by marking the rear tires to the rims. With loaded tires it is not uncommon for the rims to spin in the tire and could make a sound like you describe. Try working it again then see if the mark moves. Solution is put a little more air in the rear tires.
   / Help please, 09 TYM T330 hydrostat with ratcheting sound from the rear. #3
Have you checked the filters/oil for metal?
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
2015 Kia Sedona Van (A51694)
2015 Kia Sedona...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2014 Freightliner M2 106 Ambulance (A51692)
2014 Freightliner...
3 BATTERY CHARGERS (A53843)
3 BATTERY CHARGERS...
