HELP! PHD shaft is short
   / HELP! PHD shaft is short #11
Any parts place has it and even Wal-Mart.
Thanks again Jerry. You really made my day (or should I say night) /forums/images/graemlins/grin.gif
   / HELP! PHD shaft is short #13
Gerard, don't forget to check to make sure that PTO shaft isn't too long and can be jammed together and against the tractor PTO when the PHD is lowered into the ground. That can do serious damage.
   / HELP! PHD shaft is short #14
I agree with Bird. Take the auger off and let your 3PH all the way down. Make sure you still have some play in the shaft.
Common problem on smaller tractors.
If it is let us know, we will guide you to the right place to adjust the length.
WOW! I didn't realize that. I'll double check what you and Bird have stated. I'll let you know. Thanks.
   / HELP! PHD shaft is short #16
Best to do, is putting the implement in lowest position, slide out the ends of the pto shaft, and put the couplers on both plined shaft ends. When you hold them next to each other, you can see how much play it has when the shafts are slid into each other.
Once i bent a 100 Euro PTO shaft with endpiece, when i took a aharp corner with a too long PTO shaft... the endpiece moved eccentrical in turning circle of about an inch... It made my drum mower shake over the field, and with a manure tanker, the wheel bolts of a front wheel ran loose because of these vibrations... /forums/images/graemlins/confused.gif
</font><font color="blue" class="small">( I agree with Bird. Take the auger off and let your 3PH all the way down. Make sure you still have some play in the shaft. )</font>
Hi guys. I did as "quoted" and I didn't find any problems. I dug a practice hole about 1/2 to 2/3 of the shaft and it seems to work great. Smooth as glass. Hopefully at full depth it will be the same. I'll let you know. Thanks. /forums/images/graemlins/smile.gif
   / HELP! PHD shaft is short #20
Great Thread, I am first time tractor owner with only just over a year and still no PTO implements. But they are coming soon and I am weary of the danger of all that spinning material. I have wondered about how to set proper drive shaft length and now not only have I read it, I have a diagram thanks to Don
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
International 475 14 ft Disc Harrow (A52128)
International 475...
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
2023 MECALAC AS600 WHEEL LOADER (A51242)
2023 MECALAC AS600...
