Help on oil leak valve cover Cadet 782
   / Help on oil leak valve cover Cadet 782 #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
Don't know what is going on, oil bubbles out of retaining bolt on cylinder 2 (left) when model 782 17 hpp KT17 is running. Tightened bolt, still bubbles out....
Ideas?
Thanks
Mike
Winchester VA
Ideas?
Thanks
Mike
Winchester VA
   / Help on oil leak valve cover Cadet 782 #3
Not sure if this helps or provides any ideas, but my Cub 1864 (Kohler 18hp) had been leaking around the valve covers. Bolts were fairly tight, so I decided to take the two valve covers off. Cleaned the head seal area up with a mill knife and alcohol, did the same to the plastic valve covers. Used some RTV/Permetex and put them back on. You may try putting a little bit of Permetex around the head of the bolt so it seals against the top of the valve cover? Not sure how well that would work though
I have about 5hrs of use so far, and everything seems to be fine, well almost, I have a PTO seal leak I'm fixing now, but that's a different story.
   / Help on oil leak valve cover Cadet 782 #4
   / Help on oil leak valve cover Cadet 782 #5
close up
   / Help on oil leak valve cover Cadet 782 #7
Take head off and see if the gasket is blown.
   / Help on oil leak valve cover Cadet 782 #8
   / Help on oil leak valve cover Cadet 782 #9
The KT17 is just a flathead/L engine, so removing the heads and replacing the gaskets is a very easy job, just unbolt them, remove them, put on new gaskets (avail at small engine/Kohler shops), and properly retorque the heads back down- should get rid of the leak which is probably residual blow-by oil getting past the gasket.
-Fordlords-
   / Help on oil leak valve cover Cadet 782 #10
-Fordlords-
City of Tampa (842) VIN: 2C3CDXAG2DH670595 **Title MUST be transferred into buyer's name INCLUDING (A51694)
City of Tampa...
New Bobcat 18" Bucket (A50774)
New Bobcat 18"...
750 Gallon Concrete Fuel Tank (A50774)
750 Gallon...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
Vermeer 840 Discbine (A50774)
Vermeer 840...
CFG Industrial QK20R (A50121)
CFG Industrial...
