help on m110gx
/ help on m110gx #1
junior20762003
victoria tx
l3400/m110gx
Just wondering if anyone has had any issues with the kubota m110gx ... a couple days ago I encountered a problem with the tractor running fine then slowly shutting down all of a sudden as if its bogging down or getting air and if you try to restart it it'll just turn over but if you let it sit for a while it'll restart fine and work properly for 3 to 5 minutes then die out ... i replaced fuel filters and still have the same issue ... even when the tractor shuts off and you check the fuel filter and its full of fuel so i don't think its fuel related ... the tractor has 137 hours on it any help would be appreciated
/ help on m110gx #2
Maybe fuel solenoid on inj pump is not staying engaged.
/ help on m110gx #3
My 135GX had a problem from the start with dirt plugging the fuel tank vent hose. I noticed that it had sucked the tank sides in. Kubota sent me a new top fuel tank vent assembly (I live 150 miles from the closest dealer) and while replacing it, I noticed the hose was plugged. This hose actually ends attaching to a tube that I believe goes into the cab rear post for protection. The only way this could have been filled with dirt is if someone, somewhere intentionally did it. It would cause an air lock in the tank resulting in a problem just like you have. You have probably already checked the tank but I thought I would mention it as our tractors are basically the same. I also had a problem similar to yours my first winter - gelled fuel - but you certainly don't have that now. Run for a few minutes, run rough, die. Let sit, try again, repeat.
2003 INTERNATIONAL 9100 6X4 T/A  VACUUM TRUCK (A59911)
2003 INTERNATIONAL...
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
1660 (A59213)
1660 (A59213)
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2026 Kearney 102"x32' Gooseneck Trailer (A64119)
2026 Kearney...
