Help on JD 420 Inside Bucket Width
/ Help on JD 420 Inside Bucket Width #1
Gringo_Viejo
Starr County, Texas
JD4300, Kioti DK65S
My JD 4300 has a 420 FEL with a 61" outside width bucket. I need to know the inside width at the lip to order a tooth bar. The tractor is 500 miles South, and I am not close to a dealer.
I would very much appreciate it if anyone with a convenient 420 FEL could help me out with the inside width. My guess is that it is about 60.75", but I cant remember if there is any interior bracing at the lip.
Thanks in advance.
Gringo Viejo
/ Help on JD 420 Inside Bucket Width #2
I think its closer to 60.5". You may also need the cutting edge metal thickness. I know I did when I bought my toothbar.
Terry
Terry,
Thank you very much. I am getting my bar from Carver, and the only thing they said that they needed from me was the inside width. The information that I have read on the Carver bar said that it would not fit a bucket with a bolt-on cutting bar, so I suppose they assume a nominal thickness for the cutting edge. Just in case, if you recall the thickness of the cutting edge it might be nice to have.
Thanks again,
Gringo Viejo
/ Help on JD 420 Inside Bucket Width #4
Doh... silly me. Why don't you call the JD dealer and ask him to get you the measurements? Or just stop by and measure yourself. I have a 410 loader with a 61" bucket and I believe it is the same one. Not a 100% sure, but I bet it is.
Terry
