kthompson
Elite Member
- Joined
- Sep 12, 2008
- Messages
- 3,509
- Location
- South Carolina
- Tractor
- Kubotas B2710, M6800, L6060 cab, Volvo EC excavator, 2 ZTRs and various implements.
First this is on a Volvo excavator, EC454. It is my impression they are a general design so the exact machine may not matter. It has a Mitsubishi engine if it matters.
Had issue with fuel solenoid not working. Found out power was not reaching it. Begin running new wire and it worked great. Ran the engine for about 5 minutes and it shut down. The fuel shut off solenoid was very hot and had burnt up with blowing the fuse. Order a new solenoid and replace it and it worked fine for about 20 minutes as I ran the machine doing some brush clearing. Same thing again, the new solenoid was way hot, and it burnt out.
The mechanic is not certain the issue and I fully believe in the necessary wires replacement he got a wiring mistake. It will crank, run and cut off the way it is wire as it is supposed to. If the wires were crossed seems it would not perform the functions properly as it did. Is it possible there is power going to one part of the solenoid that should not be powered once it cranks? Can anyone tell me (has three wires) anything about what each wire should have power on it as it cranks opening the fuel valve and then when running? Does it keep power on one of the wires to keep it running? The amp draw on the replacement was to me very reasonable. Think it was just over 4 amps when it was cranking and running.
Any help would be appreciated. Have a second new solenoid but really don't want to burn it up.
Thank you,
Ken
Thank you,
Ken
