Help on ATI All in wonder 9600, no sound to HD
   / Help on ATI All in wonder 9600, no sound to HD #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
If I could record tractor sounds, this post would be semi-related ! /forums/images/graemlins/blush.gif
That said, I have a ATI All-in-Wonder 9600 card in my pc All seems to work flawlessly with it EXCEPT for when recording to hard drive.
There is no sound on playback…video YES, just no sound.
Wire goes from wall to DSS input, DSS output to VCR input (VCR records just fine). VCR (component out) to video card input. If I take any of the wires apart midstream, depending on which one, the sound or video will go out on pc/monitor, suggesting all are connected properly.
At first, I only noticed it when I tried to record a concert, I figured there was some digital protection which is/was fine by me. However, as I slowly tried to record other things to see how it worked (news, commercials…..) I realized it was recording NO sound, video yes, just no sound.
Any ideas?
Oh, and I’ve uninstalled/reinstalled, though I intend to do that again.
   / Help on ATI All in wonder 9600, no sound to HD #3
Richard, It might be a driver issue, download and install new drivers. I had plenty of problems with my AllInWonder when I first installed it, but it works great once the buggies are fixed.
No audio is captured when using the S-Video or Composite inputs on the ALL-IN-WONDER RADEON
This issue affects the ALL-IN-WONDER RADEON when used with:
the ATI TV Player from Multimedia Center 7.0
RADEON Windows 2000 display driver version 5.13.01.3100
When attempting to capture video from an S-Video or Composite source no audio will be recorded.
If video is captured from the TV input, audio is recorded correctly in the resulting video file.
The 5.13.01.3100 driver release was intended for use with ATI's Multimedia Center version 7.1. When used with ATI Multimedia Center 7.0 some functions of the ATI Multimedia Center software may not function correctly.
I've uninstalled the card (only drivers, not physically) and reinstalled. I ALWAYS seem to have an issue on installing software for this card, it never works first time.
Anyway, I completley disconnected the S-video line so that wouldn't be an issue, I once discovered what you mean about no sound when using S-video. so I took it out of the loop.
Just got done with reinstall and same thing...funny thing is, I looked in my archives and I DO have some clips recorded with sound. Nothing worth keeping (news while in shower) so none of them were concerts (potentially protected?)
I just now got done taking the VCR out of the loop and went straight from DSS to input of card. Same issue /forums/images/graemlins/confused.gif
oops, forgot to mention, the line in, IS connected. When I disconnect it, all tv sounds die. plug back in and sound back over speakers, just not when recording.
hmm...could perchance there be a windows slider control... (off to go look)
   / Help on ATI All in wonder 9600, no sound to HD #6
If you have windows XP do this:
Start -> Control Panel -> Sounds and Audio Devices.
Click Audio tab
In center of window is group called "Sound Recording". You can select your default recording device here. Click the Volume... button. This brings up the "sliders" for adjusting recording volumes and sources. Make sure the "select" check box is checked for your line in, and/or ATI audio in port.
These directions are slightly different for Windows 2000 but should be good enough to get you in the right area to find win 2k's similiar settings.
This should fix the problem (hopefully).
2018 INTERNATIONAL LT625 DAYCAB TRUCK (A53843)
2018 INTERNATIONAL...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2013 John Deere 824K Wheel Loader (A55218)
2013 John Deere...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
