Help on a lt 150
/ Help on a lt 150 #1
hoc342
taunton
JohnDeere111h
Was cutting the grass and then ran out of gas. Filled it went to start it, nothing totally dead. Battery is good. I replaced the key switch and solenoid. I checked for continuity on the switches and there fine. At wits end. I cross jump the solenoid and it starts till i take off the brake in wjich the motor stops, a d go to turn the key totally dead. Any help would be much appreciated.
/ Help on a lt 150 #2
You really should use spell checker.
So when you had the motor running and then released the brake, where you on the seat?
Richard
/ Help on a lt 150
Yes I was on the seat. I checked the seat switch for continuity and it was good. Also checked the brake switch and the pto switch for continuity and they were good.
/ Help on a lt 150 #5
It sounds seat switch like or in the circuit. There are different versions depending on your build. As you are checking these switches, do you know what they are supposed to do or just going by continuity one way, not the other? Brake and PTO switches can have 2 terminals that are normally open and 2 that are normally closed. Some fairly common things on these are the little bolt for the paddle which activates the PTO switch breaks and will cause a no crank situation. Engine mount bolts seem to come loose a fair amount on these, the engine shifts damaging the harness at the relays behind the engine.
/ Help on a lt 150
I've tried the switches both ways. I'll check the harnesses
/ Help on a lt 150
The only way it starts is crossing the solenoid. Then as its running when I release the brake it dies. When I turn the key I get nothing no click no nothing. I replaced the solenoid and a new key switch so far.
/ Help on a lt 150 #8
turn the pto off
/ Help on a lt 150
Pto isn't on
/ Help on a lt 150 #10
Check the PTO switch (how many wires go into it?). If it has more than 2 wires, then the switch may still be the problem.
/ Help on a lt 150
Ok I'll check it tomorrow when I get out of work. Thanks
/ Help on a lt 150
Ok I found the problem. The paddle on the pto rod lost the bolt so I bought a new one but the paddle doesn't push the switch enough to operate. So I wire fied a piece of wooden shingle and it pushes the switch back enough now
But its still not right cause when i shut down the pto and lift the deck to its highest level the blades engage by themself.
/ Help on a lt 150 #13
Check all the plastic parts for wear and distortion (bent not making contact like it should) or breakage, then those parts will most likely need replacing.
/ Help on a lt 150 #14
So when the bolt had snapped, the rod that came up from the bottom was able to drop down enough that one of the step bushings came out of place. They tend to do that if the fine spring that goes up to the body from the rear of the engagement rod is hooked up. You should be able to wiggle things back into place and reinstall the bolt. I suppose that it is possible that the lever return spring on the arm went awol at the same time.
HAMM HC50i VIBRATORY ROLLER (A64278)
HAMM HC50i...
NexTier Frac Manifold T/A Trailer (A64194)
NexTier Frac...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
