Price Check Help on a Ford 3910
   / Help on a Ford 3910 #21
Depending on how clean and straight it is, the price could get to $15K. For sure $13K.
I've got $10K in mine without Loader.
Yes......but yours is magnificent,....looks like a museum piece !
   / Help on a Ford 3910 #22
   / Help on a Ford 3910 #24
That's a nice size tractor and I'd like to hear a little more about those Ford 3910s. What motor? What transmission? What were common options? How are parts?
What's good and not so good?
How are the front wheels driven by the front axle? At that time I imagine it could have been bevel gear drive, traditional sliding splines, or even some sort of universal knuckle.
rScotty
   / Help on a Ford 3910 #25
rScotty
The venerable 3cyl that was used for many years in many HP variations gas or diesel. Mine is diesel.
Mine, and the one in the OP's pic, is and 8spd forward, 4spd reverse using a mechanical shuttle.
Not sure about options. If RickB sees this he will know. Mine, and the one in the Op's pic has dual rear hydraulics and auxiliary hydraulic pump.
Parts are very available. A quick Internet search will reveal that. The Midwest CNH parts warehouse is 55 miles from me. I can get most parts the same day I need them.
Goods. Very balanced tractor with a lot of features that aren't even found on new tractors. Hydraulic speed can be adjusted to include the 3pt lift. Can then be adjusted again at the rear remote couplers. Has the normal brake pedal lock and additionally has a lever type brake lock that locks the powertrain so all four wheels are locked. Wet hydraulic brakes. Independent hand lever PTO engagement for soft starts. Interchangeable 3pt link arm balls to switch between CAT I and CAT II without using any tools. Of course all the normal stuff such as Draft Control, Position Control 3pt. Great tractor for it's size.
Bads. Only one I have is turning radius is big. This is caused by the design of the front axle which uses the old school King Pin knuckles with Double Cardan axle joints at the knuckles.
Front axle drive is engaged/disengaged by a sliding spline gear enclosed in a small transfer case added to the front of the rear axle assembly. Engagement is done by lifting a T handle on the right side of the transmission near the brake pedals. The OP's pic shows this T handle and he has it engaged in 4wd. A very easy to use system that is bullet proof durable.
These 10 series Fords are very good tractors that are sought after. Great dependability. Easy parts availability. Large production numbers so chassis parts are available at bone yards.
I suspect the OP will miss his 3910 when he tries to replace it with a Compact. His tractor is more of a Utility Class than a Compact Class.
   / Help on a Ford 3910 #26
If that Ford 3910 were in my barn......it would NEVER leave my property!
   / Help on a Ford 3910 #27
It fits my operation very well. Does all the medium duty chores. I'll never sell it. Pretty sure my Sons won't either. :)
   / Help on a Ford 3910 #28
I don't see a Ford FEL for those older Fords driving the price to $15k...no way. Circumstances at the sale, seller, seller's interest in the sale, seller's overhead if a business, cash payment, come prepared to buy...trailer and such to haul it off, operating hours, condition, and especially location of the country all play a part in the price.
   / Help on a Ford 3910 #29
A much smaller 32HP Ford 1920 4x4 FEL with under 1200 hours, and in excellent condition, will bring close to 15K in the NE area.
   / Help on a Ford 3910 #30
Location plays a role. An immaculate low hour 4610 MFD with a synchro transmission, loader and 2 pump hydraulic system with closed center remotes would fetch $15K in the Northeast.
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
2025 JMR 78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 78in Dual...
Kimball Midwest Wire Cabinet w/Wire (A59076)
Kimball Midwest...
J and L Cargo Express Shadowmaster Enclosed Trailer (A56435)
J and L Cargo...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
