HELP- new L3400 - green fluid on floor!
   / HELP- new L3400 - green fluid on floor! #1
Ranch120
Here is one for all of you seasoned Kubota guys: got my new Kubota L3400 w FEL and 60" box blade delivered yesterday. Ran it for about 2 hours. This morning I had a greenish fluid on the garage floor underneath. Pretty close to the front end of the tractor. Looks like an antifreeze but I'm not sure. The 2 hours I ran the tractor was mainly some FEL work with dirt.
Can anyone give me some ideas?
   / HELP- new L3400 - green fluid on floor! #2
Probably is antifreeze. New tractor worked hard for the first time may have "burped" a bit. I don't think that there is an overflow tank, so it makes it to the floor. Could be wrong....
jb
   / HELP- new L3400 - green fluid on floor! #3
RANCH120,
WHEN I GOTMY NEW B3030, I HAD ABOUT 25 HRS. ON IT AND I HAD THE SAME THING HAPPEN TO ME! I LOOKED AND LOOKED AND THEN ONE DAY I WAS CHECKING THE OIL AND THERE IT WAS, THE CLAMP ON THE RADIATOR HOSE OF THE THERMOSTAT ON TOP OF THE ENGINE WAS THE CULPRIT. I JUST TIGHTENED IT AND WATCHED IT FOR A COUPLE OF DAYS AND NO MORE SIGN OF ANY LEAKS. JUST A THOUGHT!! LET US KNOW.
   / HELP- new L3400 - green fluid on floor! #4
When my L3400 was new it did the same thing you described. It was coming from the overflow tube on the radiator, I kept and eye on the antifreeze level and just kept using it and it finally went away. I think when the dealer prepped it they just overfilled the radiator a little bit. It's been about two years now and it has never leaked another drop and the level has not gone down in the radiator. Bob
   / HELP- new L3400 - green fluid on floor! #5
My L3400 had a few drops fall on the trailer when I picked it up at the dealer. I also found some on the frame. Turns out it was from the install of the block heater. I've noticed no other drips.
   / HELP- new L3400 - green fluid on floor! #6
I had a block heater installed on my L3400 before it was delivered. It was dripping anit-freeze every day from under the engine on one side. I could not find a leak. I noticed that between the frame and side of the engine there was an area to trap fluid. I don't have a loader so I pulled the plastic thread plug from the frame and a bunch of anti-freeze poured out. No more drips. It would have eventually quit. Maybe that area got filled when they serviced it. Just another possiblility.
43006 (A51691)
43006 (A51691)
(10) IH Suitcase Weights (A50515)
(10) IH Suitcase...
New Holland TN60A (A50120)
New Holland TN60A...
MINI EXCAVATOR BUCKET 12" (A50322)
MINI EXCAVATOR...
2014 Ford Escape (A50324)
2014 Ford Escape...
Guard Rail Joints (A51692)
Guard Rail Joints...
