Help - New Holland TC30 Injector Pump Replacement
   / Help - New Holland TC30 Injector Pump Replacement #1
OkieFarmer78
John Deere 6105M
Recently purchased a mid 2000's New Holland TC30. It has the little Shibaura N843 - 3 Cyl Diesel.
I purchased the tractor not-running. Supposedly, the injector pump was gummed up.. and was disassembled prior to my purchase. I have the bucket of parts and the pump housing..and some of the internal parts are pretty bad.
A re-man injection pump will be here in a day or two, but curious on timing. I believe the timing is set by the amount/thickness of the shims under Should be a plug / play / and bleed? But before I did something to damage the new pump / pump cam / etc, I wanted to make sure there was nothing else needed to set the timing, and regardless of current cam position, I could bolt this pump down, hook up the lines, blead the system, and go.
Thanks
   / Help - New Holland TC30 Injector Pump Replacement #2
I'm sure someone with more knowledge on your TC30 will chime in; however I do not think it is plug & play when replacing an injector pump on any of the 3 or 4 cylinder diesels in the NH TC series..
I believe you need to verify the Pump Timing by doing a Spill-Timing procedure... I don't have a TC30 Manual but I know that is the procedure in the TC35 - TC40 - TC45 Service manual....
So make sure you check before just bolting it on...
   / Help - New Holland TC30 Injector Pump Replacement #3
The TC29, 29D, 33, 33D manual I have also mentions the "Spill Timing" procedure under the Timing and Governor Adjustment section.
It sure doesn't seem like its.....just bolt the new/remanufactured injection pump on and fire it up without a lot of checks/adjustments.
Thank you for chiming in. I dont have the manual, and my knowledge of these shibaura's is limited.
I'll see what I can find.
   / Help - New Holland TC30 Injector Pump Replacement #5
I would hope whoever you purchased the re-manufactured pump from could send you a procedure specifically to your tractor for its calibration.
I asked, and even called the local dealer... nothing. The New Holland dealer couldnt even source a pump for me.
I've spent the last 30 minutes digging, trying to find the procedure for the spill-timing. I understand what that is, but theres nothing I can find on how to set it. Does your manual happen to have the instructions?
   / Help - New Holland TC30 Injector Pump Replacement #7
@OkieFarmer78 - if you are keeping this tractor I think it would be well worth your wild to have the correct shop manual...
You should be able to find a digital copy on places like ebay & the such or you could purchase an digital download version from places like The Repair Manual & download it instantly for around $35 - $40. There are others places too; I only mention The Repair Manual because I have purchase from them previously. (Use the search tool in the top left type "TC30")
I do have the pages for the TC35 thru the TC45 but unsure if the procedure is the same on the TC30, so I would only use it as a reference.
It does list the Timing for the N843L engine but the timing is for the TC35... Again for the few bucks I would just purchase the correct Manual for your TC30 to be sure.
PDF For Reference Only:
  • TC40 Injector Pump Replacement - Timimg - Spill-time procedures.pdf
This is absolutely fantastic! I will look at the timing for the tc30, but the procedure should be spot on! From what I remember, the TC35 is the same 3cyl as the TC30. The TC40 and up should be a 4cyl if memory serves...as I've had both a TC40 and TC45 in years past.
I appreciate you taking the time to download at attach this.
And I Agree on the manual!!
   / Help - New Holland TC30 Injector Pump Replacement #9
This one is a little different and does not mention your TC30 but does reference the TC29. As dlctcg has mentioned I'd be looking for a manual specific to your TC30 model.
  • Spill Timing.zip
   / Help - New Holland TC30 Injector Pump Replacement #10
If there are shims on the block or on the old ip..
Bolt it up and start it..
Btw.. I could’ve built your old pump..
1991 KALYN SIEBERT 60 TON LOWBOY TRAILER (A51247)
1991 KALYN SIEBERT...
2020 JOHN DEERE 333G SKID STEER (A51246)
2020 JOHN DEERE...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
CASE 580 SUPER N BACKHOE (A51246)
CASE 580 SUPER N...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
