Loader Help needed identifying Power Beyond circuit L3240
   / Help needed identifying Power Beyond circuit L3240 #11
^^^^ there is a link in my signature for the remotes install
   / Help needed identifying Power Beyond circuit L3240 #12
If it helps, on my B the loader has an external port for PB. It goes back to the 3pt. I can get a pic of you think it will help. Also, there it what appears to be a cover that actually is a manifold that routes from pump to fel valve. This could be replaced with a block with ports for in and out.... LD1 I think posted a pic of it in one of his hydraulic threads......
EDIT The B series and LD1's MX5100 have a hydraulic block where flow can be diverted to other uses before going to the 3pt hitch. But the Lxx40 doesn't have a hydraulic block. Pump flow goes directly into the hydraulic control/loader valve. No alternate tap is provided. And it looks like the optional single remote (if present) isn't useful for a grapple since it defeats the loader valve when selected.
EDIT There's a TBN discussion here. Attached below are the instructions for installing the Kubota L2221 (and L2222) 3rd-function valve kit. The drawings show the new tubing pieces and the ones they replace to get PB flow for the valve. I'm assuming the W.R.Long kit for Lxx40 machines includes comparable plumbing. Hope this helps, Dick B
  • L2221 kit installation.pdf
   / Help needed identifying Power Beyond circuit L3240 #13
I'm helping a friend with a WR Long 3rd function kit to power a root grapple. He has a 2012 L3240 with an Ansung loader. The schematic supplied with the Long kit doesn't show his plumbing layout. We need to identify the power beyond circuit and figure where to tap into it. Will the loader control valve be that point or is it somewhere else? Any help is appreciated.
Found an answer - see Post #12 PDF Attachment above. Good luck, Dick B
2014 International Maxxforce DT (A53317)
2014 International...
2015 INTERNATIONAL FLATBED (A58214)
2015 INTERNATIONAL...
2021 Ford F250 (A55973)
2021 Ford F250...
HUSQVARNA RIDING MOWER 42INCH (A56859)
HUSQVARNA RIDING...
2021 SAVANA 4500 BOX TRUCK (A57880)
2021 SAVANA 4500...
2002 International 9200i Truck (A55315)
2002 International...
