Help needed by Belleville, IL on used JD
   / Help needed by Belleville, IL on used JD #1
Guys....I'm looking at a used JD at a dealer near Belleville, IL , I live in western PA and I'm seriously considering buying this machine. I got pictures and spoke with the dealership. I was wondering if anyone is from around here and could give the unit a quick look over. Please PM if you can help.
   / Help needed by Belleville, IL on used JD #2
Since you are not finding anyone to check it out, you might want to contact the former owner and talk with him about it. That's what I did when I bought from a dealer via pictures only. Dealer should be able to put you in contact with the former owner.
   / Help needed by Belleville, IL on used JD #3
you are looking at a tractor pretty far away!
i would say if it is used tractor, just hold off if you can, till you find something near you. that will only take a day to drive to and back home to look at.
sight un-seen can always be trouble and risky.
if it is a new tractor, i would check locally and pay couple hundred more just to have the place near by.
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2007 CATERPILLAR 930G WHEEL LOADER (A51246)
2007 CATERPILLAR...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
