help need hydraulic filter
   / help need hydraulic filter #1
davidseaquist
Escondido California
2005 Ingersoll Rand Bl370b
I posted in the equipment forum.
I am looking for a filter element for my Ingersoll rand bl370 the same tractor as a Bobcat b 300 [ earth force ] tractor loader backhoe.
I called Volvo they quoted me $190 for a filter element assembly[ 15395858 ]
I called Bobcat they quoted me $167.31 for a filter element assembly [ 6961199 ] .
I am hoping to find replacement elements and o-rings generic I would think they would be a lot cheaper.
Thanks David
   / help need hydraulic filter #2
did you ever find something?
   / help need hydraulic filter #3
   / help need hydraulic filter #4
guessing no one found a cheaper solution? :(
   / help need hydraulic filter #5
   / help need hydraulic filter #6
Can call, but there is nothing listed for the Bobcat equivalent (B300) of my machine in that file.
236 for a filter seems pretty steep to me...
   / help need hydraulic filter #7
For that price i would pull the filter and install and external return side filter housing and filter.
   / help need hydraulic filter #8
If this is a hydrostatic charge filter is is a moderately high pressure filter, rated to about 1,000 psi vs the 100 psi of an engine oil filter or about the same for a suction filter. Housing is heavier and filter media is stronger.
   / help need hydraulic filter #9
Pardon the ignorance, how would I know if it was a charge filter?
Hadn't thought of replacing with a separate filter as noted above, but then again I'm looking to sell the machine shortly so the cost of modifying the hoses etc probably is more than just buying a filter for 1x.
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
2021 Exmark Lazer Z 60in Zero Turn Commercial Mower (A52377)
2021 Exmark Lazer...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
2015 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2015 Ford F-350...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
