help need hydraulic filter
   / help need hydraulic filter #1
davidseaquist
Escondido California
2005 Ingersoll Rand Bl370b
I posted in the equipment forum.
I am looking for a filter element for my Ingersoll rand bl370 the same tractor as a Bobcat b 300 [ earth force ] tractor loader backhoe.
I called Volvo they quoted me $190 for a filter element assembly[ 15395858 ]
I called Bobcat they quoted me $167.31 for a filter element assembly [ 6961199 ] .
I am hoping to find replacement elements and o-rings generic I would think they would be a lot cheaper.
Thanks David
   / help need hydraulic filter #2
did you ever find something?
   / help need hydraulic filter #3
   / help need hydraulic filter #4
guessing no one found a cheaper solution? :(
   / help need hydraulic filter #5
   / help need hydraulic filter #6
Can call, but there is nothing listed for the Bobcat equivalent (B300) of my machine in that file.
236 for a filter seems pretty steep to me...
   / help need hydraulic filter #7
For that price i would pull the filter and install and external return side filter housing and filter.
   / help need hydraulic filter #8
If this is a hydrostatic charge filter is is a moderately high pressure filter, rated to about 1,000 psi vs the 100 psi of an engine oil filter or about the same for a suction filter. Housing is heavier and filter media is stronger.
   / help need hydraulic filter #9
Pardon the ignorance, how would I know if it was a charge filter?
Hadn't thought of replacing with a separate filter as noted above, but then again I'm looking to sell the machine shortly so the cost of modifying the hoses etc probably is more than just buying a filter for 1x.
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
2020 21" Exmark Push Mower (A52377)
2020 21" Exmark...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2008 FORD F150 XL TRITON TRUCK (A54756)
2008 FORD F150 XL...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
