Help my ford 640 12 volt generator system is not charging
   / Help my ford 640 12 volt generator system is not charging #1
lostbit
ford 600, kubota 2680
I have been working on this for a few days, I loosened the fan belt, connected a booster battery between the armature and field terminal and the
generator turns, so the generator is OK. I just put in a new voltage regulator and still not charging??
I disconnected the field wire from the new regulator, there is no voltage being sent to the generator to cause magnitic field.
I red that I can do a quick test connecting the field wire to the battery while running, OOPS, caused the wire to get hot in seconds.
anyone know what I need to do to get this started?
Thanks
   / Help my ford 640 12 volt generator system is not charging #2
Generators produce power, you don't supply power to them ( from my VW experience ) not sure how they work on a tractor but I converted my VW to an alternator and eliminated the regulator all together, maybe do the same if its possible? That would make it a single wire to the battery (+) to keep it fully charged.
   / Help my ford 640 12 volt generator system is not charging #3
Do a search on "polarizing generator". Maybe that is all you need to do, it's worked for me several times.
   / Help my ford 640 12 volt generator system is not charging #4
12 volt and generator dont belong in the same sentance when talking about a 640. If you truly have a 12 volt battery and still have a generator, it will never fully charge unless you have a 12 volt generator from a diesel tractor from the 59 to 64 era. You either need a 6 volt battery, or complete the rest of the 12 volt conversion with an alternator and whatever else may not have been done to do a complete 12 conversion.
Sorry for not closing this post. Resolved.
The Voltage regulator I bought was bad. I replaced it again and I get a good charge Idle 500RPM reads 12.8 volts
1200RPM 13.2 Volts.
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
Pull-Behind Ripper Attachment (A49461)
Pull-Behind Ripper...
2007 PETERBILT 335 SERVICE/LUBE TRUCK (INOPERABLE (A50854)
2007 PETERBILT 335...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
