Help...my cub cadet won't move??
   / Help...my cub cadet won't move?? #1
swollen
Salisbury, NC
Cub Cadet LT1042
I've got a cub cadet LT1042 series 1000, & it's got atleast 60hrs. on it. Was mowing and the back wheels just seemed to lock up. -now, this has happen before, & I moved that engage/disengage rod on the back & this time it doesn't work for me. The lever that-that rod moves back n forth, is there suppose to be a spring on the top of it, there's a hole there, to hold it back?, cuz I can pull back on it and turn the wheels.
Does anyone kinda know what I'm talkin' about...
   / Help...my cub cadet won't move?? #2
You are talking about that lever by the right rear wheel? You pull back and down to lock it and it allows the rear tires to free-wheel? Not sure why your rear wheels are locking up while you are mowing. Still under warranty? Try the sister board lawnmowerforum.com may get more answers there.
   / Help...my cub cadet won't move?? #3
Check your brake. If you look by the transmission by the right wheel there is an external brake set up that sometimes gets sticky. That would be the first place I would look.
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
Wilrich Field Cultivator (A50515)
Wilrich Field...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A51222)
1968 CHEVROLET C10...
2012 John Deere 7230R (A52128)
2012 John Deere...
