Help mounting chainsaw & polesaw to tractor
   / Help mounting chainsaw & polesaw to tractor #1
agh
mississippi
case 485 kubota m9000
Has anyone fabricated a bracket to carry their chainsaw and also a 7-10 ft polesaw on their tractor for trimming out overhanging limbs on woods roads in your forest? I usually have boxblade or bushhog on 3 pt hitch and FEL on front of tractor. where to mount and safely carry the chainsaw and polesaw eluded me. i have an old case 485 2 wheel drive and a m9000 cab 4 wheel dr and would like to make a bracket for both. thanks for any ideas or better yet pictures if anyone has made this before. thanks agh
   / Help mounting chainsaw & polesaw to tractor #3
Make a 'scabbard' out of 3" pipe.. 3' should do.. slide the pole in.
Make a bracket out of a couple barn door handles.. essentially a piece of flat, 1" wide, 1/4" thick.. has a couple inches of flat.. then a 90' up for an inch and a half.. andother 90 straight over 5", then another 90' down an inch and a half.. then another 90 and another 2".. kind of like a flattened omega / ohm symbol... slip the bar thru 2 of those brackets spaced near each other.. one under the other.... with a bunji from the lower one up thru the saw handle and back down, keeping the saw, blade down, and in the sleave..
soundguy
   / Help mounting chainsaw & polesaw to tractor #4
I ended up using ATV gun mounts with 90 lb magnets. I stick 'em to my bucket and it holds my string trimmer just fine. Pole saw might be a bit to long to run with it like that. You might be able to mount them front-to-back somehow though.
   / Help mounting chainsaw & polesaw to tractor #5
I sure wish I had a place for a chainsaw scabbard. I ended up making
a quick-release carryall box for my hood rack.
Pictured is my axe holder. This could be a gun rack if you used open
sided brackets instead of round ones here. That would work for a
pole saw, too.
I also carry a shovel vertically in a hole cut into one of my b/h steps.
   / Help mounting chainsaw & polesaw to tractor #6
I am glad I read this post. I am going to steal both ideas. I still got hurricane Ike trees down that I have to deal with.
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
MASSAGE CHAIR (A55745)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2012 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
2012 POLAR TANK...
2014 DOOSAN G25 GENERATOR (A55745)
2014 DOOSAN G25...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
