lhfarm
I spent last winter with my old plow pinned to the front of the QA plate. That puts the plow way out front and I want to move the FEL plate forward to reduce the distance between the QA plate and the blade. I don't want to cut the plow frame since I hope to find hardware for my old CJ7 Jeep. I've spent the last few days trying to use the methods I've seen here of putting the mount points on the backside of the QA plate, as foggy1111 has done here http://www.tractorbynet.com/forums/customization/225458-front-end-loader-snow-plow-2.html
This won't work with the NH QA design, since the large cross tube blocks the back of the plate. I'm wondering if I can simple weld new tabs out of 1 1/2" sq bar stock and weld tabs on the QA plate. As you can see from the picture, my QA plate already has a set of tabs from an old plow. These wont's match up with the new tabs, unless I put a bar across the A-frame and weld the new tabs to the bar.
Do you think this new mounting arrangement will work? Are there issues I'm not seeing? Any advice, comments or suggestions greatly appreciated.
Thanks!
Thanks!
