HELP! Miller 211MVP Transformer Welder Quit!
   / HELP! Miller 211MVP Transformer Welder Quit! #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
Was spot welding some casters on to the base of a patio umbrella stand and after two casters complete I suddenly got no arc. ZERO. I checked my ground clamp. Cleaned the tip on the gun. Tried on manual and auto set. Nothing. Any clues??? Not many hours on this unit. Still on my first large spool! Only a few year old machine.
   / HELP! Miller 211MVP Transformer Welder Quit! #2
Does that welder happen to have a reset button?
If you can't get it to work, take it to American Equipment service in Kent.
American Equipment Services - Welding and Plasma Equipment Service & Repair
Whatever you do, don't take it to Precision Welder Repair in Seattle!!!!!:thumbdown::thumbdown: They had one of my welder for 45-weeks:mad::mad:! Dave Kruger has no problem lying to you about when your welder will be ready!:thumbdown::thumbdown:
Central Welding Supply, Welder Repair Service
Looking for the manual now. Didn't see a reset button but did cycle on/off.
Problem solved! Project done. :cool2:
Found the manual. No reset. Put a new tip on. Re-checked the ground clamp. Looks spot faced back side of base to double contact area. Realized the weight of the ground wire was lifting off the clamp just slightly from the area I ground to bright so only backside of clamp was contacting a baked enamel finish.
I should've known something was up because it worked fine on one cross member and when I moved the ground to the other, even though it looked like it was contacting bare metal, I guess it wasn't. Stupid me. :duh:
   / HELP! Miller 211MVP Transformer Welder Quit! #5
I like this type of ground clamp.
Yeah I am now definitely in the market to upgrade my stock clamp. It's too light with a weak spring not to get overpowered by the dang wire! :smiley_aafz:
   / HELP! Miller 211MVP Transformer Welder Quit! #9
That's about all we got on the job. They work great too!:thumbsup:
I should say, we always got the 400-amp ones.
   / HELP! Miller 211MVP Transformer Welder Quit! #10
2013 Kia Optima SXL Sedan (A48082)
2013 Kia Optima...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
DAEWOO GC255-2 FORKLIFT (A50854)
DAEWOO GC255-2...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
