help - mid pto on bx1 500
/ help - mid pto on bx1 500 #1
Persistent
Jennerstown, PA
NA
Checking over a used tractor with 395 hours.
I can get a tiny bit of side to side play from the mid pto.
I'm just talking a hair. Its not leaking at all.
The rear pto doesn't have any play.
I can tell a difference between them....ist just a wee bit.
Is that normal for a used machine? Could someone else check theirs for me?
/ help - mid pto on bx1 500 #2
I just checked mine. I get a tiny bit of play in and out. Don't know if that's what you mean by side to side. I have almost 700 hrs use on pto with mower.
i really appreciate you checking.
what i mean by side to side...i can get a tiny bit of play if i give it a bit of pressure left and right.
i also get a bit more in and out but i figured that direction would be normal.
ok thanks!
i just checked my brother inlaws on his bx. its exactly same as mine.
so it may just be that im imagining a little play or its normal.
i did talk to a guy this morning that i now who had worked for 30 years on tractors, and GTs.
he said the mid pto turns at a higher rpm and is built in with an extremely tiny bit of play...he said for heat loss.
he also said its hard to detect by hand.
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
Wooden Side Table (A61569)
Wooden Side Table...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 LandHonor LHR-ME380X1 Stand-On Track Loader Skid Steer (A60352)
2025 LandHonor...
