Rotary Cutter Help me with Rotary Cutter Poor Performance
   / Help me with Rotary Cutter Poor Performance #11
Yeah,thats your problem I bet,thats the way my first cutting is in alotta places 3-4 ft tall thick. If you wanted it to look a little better,cut again in a couple weeks,should look decent than.
   / Help me with Rotary Cutter Poor Performance #12
Without question a Bush-hog brand gives the best quality cut. The Rhino I got now aint even close to the old Bush-hog 5 ft squealer I had previously. If and when I ever buy another there will be no question what brand it will be.
   / Help me with Rotary Cutter Poor Performance #13
I suppose it could be related to the height of the grass. The grass I was referring to was about 5ft tall and VERY thick. Therefore, I have to keep the cutter several inches off the ground when cutting. Maybe it will look better the next time I cut.
why several inches? it's either coing to cut it or not.. slow down and cut at a lower height and you will likely get a better cut.
soundguy
   / Help me with Rotary Cutter Poor Performance #14
Trook, I don't think you have any serious problems here.
Five-foot growth is pretty darn substantial stuff for any 5' cutter/tractor combo to handle. The first run through such a patch isn't going to be picture pretty and I'd expect a lot of neatening subsequently. Also understand running the cutter a few notches higher through it on the first run........done the same thing...........knock it down to something manageable first without being too hard on equipment and then go back on later cuts to make it neat.
Your R-4s are definitely wider than regular ag tires and are laying more material down in front of the cutter than R-1s would but it's all in the nature of the beast. Besides, hasn't the Southeast gotten quite a bit of moisture this Spring? If you're material is wetter and greener then it will be more likely to resist cutting since it's moist and maleable.
Lastly, there's nothing wrong with your shredder. If you want to change the blades on it, fine. Did the same on my riding mower. I've actively used 5 different brands of cutters.....Mohawk, Corsicana, Howse, Bush Hog, and Dale Phillips........and have rarely found a noticeable difference in the way they cut a piece of ground. The way I had the machine set and the condition of the blades was always the primary culprit in any trouble I had versus brand or deck design or whatever. Others on here say they see a difference, okay, that's their experience and I can't quibble with it. I don't see it to any real extent.
KOMATSU D39PX-24 CRAWLER DOZER (A52707)
KOMATSU D39PX-24...
2023 John Deere 8RX 370 Track Tractor (A53485)
2023 John Deere...
UNUSED FUTURE 32"...
Mini Margaritaville Truck (A55853)
Mini...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
