Help me value my Case IH 585 for sale
   / Help me value my Case IH 585 for sale #1
Jrasband
Platinum Member
Southwest VA
Kubota M7060, Case IH 585 4wd, BCS 853, Kymron ZX22
I am ready to sale my Case IH 585 tractor now. I am hoping that folks who have thoughts on what they think this tractor is worth will give me feedback.
I have had it for about a year. I bought it for $16,700 including delivery. I have since put about $2,000 into it (in parts, not including labor).
What I have done:
- Changed all fluids and filters. Changed the hydraulic fluid twice, the second time flushed it out with diesel fuel, and it is now clean and clear.
- Front rims have been replaced with heavy duty ones.
- Went through the shifter assembly and now it shifts very easily.
- Fixed the brake pedal latch for left and right pedals, and now it does not slip out. Also fixed the clutch pedal hinge point, which was worn out.
- Have had the fuel tank out multiple times, and it has not leaked since the last time I took it out a few months ago.
- Just replaced inner and outer tire rods, the battery, the power steering seals, the PTO seal.
- Added the canopy to the tractor.
- The tractor was repainted before I got it, and I have touched it up and painted some things black.
Some issues:
- The wiring harness for the tractor is in need of repair or replacement.
- The RPM gauge works, but the other gauges do not work.
- The front wheel drive switch was working but is not at the moment, so tractor is stuck in 4wd.
- The hour meter does not work because the wire was cut at around 1,800 hours.
- The only leak on the tractor comes out of the top of the transmission. The plate needs to be removed and sealed, only leaks during operation.
The parking brake works great.
About the pictures:
These pictures were taken before I painted the rear wheels black, to match the front wheels. I will also be setting the rear wheels in from 88" to 80" outside. Before I changed the front rims, the front wheel spacing was set out to 84" outside.
   / Help me value my Case IH 585 for sale #2
Based on a quick search and what is wrong with it 15 to 20 but closer to the lower end of the scale
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
Case 1083 20ft Corn Head (A56436)
Case 1083 20ft...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
