Help me make a choice!
   / Help me make a choice! #1
DmansPadge
Veteran Member
Orange, TX
Kubota B2620, Toro 2000 Series Z Master
I have about 1 1/2 acres of flat land that I just bought to build on and want to buy a new Cub. I have been looking at the LT2180 and the GT2521. I will use it mainly for mowing but I am also interested in the front dozer blade for leveling sand and smoothing my rock driveway. I don't know much about the blade... is it adjustable up and down? How does it attach? Is it easy to take on and off? Any suggestions would be appreciated. This will be my first riding tractor since right now I have 1/4 acre lot and mow with a Honda self propelled walk behind.
   / Help me make a choice! #2
I believe Bob Skurka has a Cub Cadet. Try to PM him and see if he can help you. Gerard
   / Help me make a choice! #3
I am not familiar with this new line of lawn equipment, but generally speaking, the GT versions have a stronger frame and larger tires which majes it more suited for ground-engaging implements. What is the price difference?
   / Help me make a choice! #4
Along with the larger tires and frame, the"25" series has a cast iron rear end that will aid in longevity.
As far as the blade, they are adjustable up and down, right to left.
I have never installed one, so i cannot comment on the degree of difficulty of installation.
Thank for the input. The list price is $1000 difference. But as riches139 mentioned, it has the 150lb. cast iron rear axle. It also has a 21 horse Vangaurd instead of an 18, bigger tires, thicker deck and a few other options. I don't mind spending the extra if I'll be happier... however I don't want to buy more than I need.
I'm also open to other brand suggestions but from what I've seen so far, the bang for the buck goes to Cub Cadet. Thanks for everyones info.
2018 Bobcat T590 Compact Track Loader Skid Steer (A49346)
2018 Bobcat T590...
2007 Ford F550 Flatbed (A50397)
2007 Ford F550...
2016 Freightliner M2 Gradall D152 (A50860)
2016 Freightliner...
2025 JMR 40in Grapple Rake Mini Skid Steer Attachment (A49346)
2025 JMR 40in...
2022 Club Car...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A50397)
2023 New Holland...
