Help me lube my drawers!!
   / Help me lube my drawers!! #1
dullpain
Platinum Member
Middle Tennessee
Kubota M5700 4 WD w/ FEL, Kioti CK4010SE HST, 21' Flatbed Gooseneck Trlr.
Now that I have your attention - I need to lube the drawer slides on my toolchest , top box, and rollaway cabinet. The drawers are not ball bearing , but rather steel slides. They work relatively well but there has to be a suitable lubricant out there that will make them work better. All of the grease I have tried makes the drawers sticky and hard to slide. Heavy weight oil just does not last, runs everywhere and makes a mess, same with light weight oil.
Need something that will stick to slides/runners, work smoothly, not run??
Any suggestions. thanks
   / Help me lube my drawers!! #2
Afternoon Dullpain,
Perhaps a small amount of powdered graphite ?;)
   / Help me lube my drawers!! #3
a spray can of "chain lube" graphite or vasiline
   / Help me lube my drawers!! #4
Try a solid chunk of home-canning paraffin wax. Its easy to rub on the sliding surfaces, no overspray, and any chips that fall off won't stain. I use it a lot for wood drawers, metal drawers, wood screws, and even for a dust resistant lube on the threads of my 3-point upper link. And it's easy to carry a chunk in the toolbox.
   / Help me lube my drawers!! #6
Probably the best lubricant I have ever used is Prizim made by Drummond American. It starts out as thin as alcohol and when the solvent dries it turns into a great sticky type stay put lube. Great for door slides, hinges, door strikers, garage door tracks, etc... My single favorite lube in a can.
Drummond American Catalog Display
   / Help me lube my drawers!! #8
Try bees wax, it is easy to put on and lasts forever
   / Help me lube my drawers!! #9
Ditto
Never tried it on metal drawers but on wood screws and circular blades cutting aluminum siding it works well.
   / Help me lube my drawers!! #10
I 3rd the motion for silicone or super lube. This is what JD recommends on its 3ph balls and swivels. I've used it on shower door slides/wheels, screen door slides (made it work A WHOLE LOT BETTER) and other sliding surfaces.
Remove any of that stuff you've tried with solvent or alcohol. You can clean up any silicone gook after look use with denatured alcohol.
Ralph
20" Sea Container (A47384)
20" Sea Container...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
90018 (A48082)
90018 (A48082)
2008 Chevrolet Express Cargo Van (A52377)
2008 Chevrolet...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
