Help me justify a TILLER.
/ Help me justify a TILLER. #1
tony123
Platinum Member
Travelers Rest, SC
YMG2000D
I'm working on a vegetable garden (our first) for next season. The garden will be 3 rows at 4' x 70' or so. This is too much dirt to work by hand, but tillers are a little expensive to be a one dimensional implement.
Can you guys help me with a list of tasks that a tiller works well for? If I could get my uses up to a few projects, my wife would be on board. :eek:
Thank. Tony
/ Help me justify a TILLER. #2
Although I read alot here , due to time constraints , I usually do not post , but since I have my Semi parked for a few days , I'll give you my opinion .
You pretty much hit it on the head being that tillers are 1 dimensional . My neighbor and myself have TC-30 NH tractors . He bought a tiller , ( believe its a 72" ) and although he has used it a few times in his lower field area and it does do nice work it just a couple of passes , the tines take alot of abuse in non-garden type applications , ( rocks are pretty hard on tines ) .
Were as I bought a 72" king cutter disk and have used it pretty extensively for over 3 years now with little damage to any of the blades / disks themselves . It does require a few more passes to get good depth and soil break up , but in the end you would be hard pressed to tell the difference between what was disked versus what was tilled .
I disk down both sides of my driveway to keep weeds down , ( both sides are roughly 25' x 800' each ) , plus I do a 12' border on the south side of our property and the west side for fire protection , ( west side is downhill from home , while south side is both downhill and the normal direction from which the afternoon winds come from ) . Last summer , while I was disking the driveway , he was tilling a section of his field . Although his field came out looking pretty good , since tillers leaves no tracks , I can only imagine what the tines looked like since it was virgin soil . But 2 months later the amount of regrowth was identical both in his field and next to my driveway . So in my opinion , the tiller did no better job working the soil than my disk did . Also after a few passes , my disk will cut just as deep as most tillers will , with alot less strain on the tractor .
If you were looking at a bigger garden area , then maybe I would look at a tiller , but for the size you are stating , I could not justify the cost difference between a disk versus a tiller .
Take Care ,
Fred H.
/ Help me justify a TILLER. #3
I have both a disk and a roto tiller and I use both. I use them for food plots the disk will not work in dry hard ground the tiller always tills.
The tiller tends to collect roots reall well, too well:( . My ground is very hard, clay and rock in fact once while doing some landscaping my shovel was boucing back only breaking small chunks (golf ball size) I got the tiller out and it busted up the ground into powder 4 inches deep:cool:
One other use could be for churning compost, also they are heavy and work well with the front loader work sometime I use it to break up some dirt for digging.
I would not own one if it were not for the food plots.
/ Help me justify a TILLER. #4
I got a great idea!! Go to wally world , buy 2 CHEAP shovels, hand 1 shovel to her,,,,,,,,,,, problem solved!!!!!!!!!
Just kiddin!!! good luck on your aquisition
/ Help me justify a TILLER. #5
Okay I will try my best to help because I think every man should have the equipment he deserve's ... you can till the garden, flowerbeds, yard, fencelines (for fire protection), sides of the driveway for weed controll, you can till the neighbors (Good for neighbor relationship) garden, flowerbeds, yard, fenclines, side of the driveway! Ohhh ... did I mention you can even till the drive way!! Well Now I quess you can just till anything, most importantly you can till your mother in laws garden .... Good Luck hope this helps and you get a tiller!!!
/ Help me justify a TILLER. #7
Thank. Tony
My tiller is a used Yanmar RS-1200 (4-ft wide) that I bought a few years ago for $300. Spent another $150 for a new pto shaft and a slip clutch. Use it with my Kubota B7510HST (21 hp engine, 17 hp pto) for the veg garden and to install a lawn around my new house.
To keep the stresses down on the tiller, I plowed the lawn area with my middle buster plow ($140 at Tractor Supply) before hitting it with the RS-1200.
/ Help me justify a TILLER. #8
I want, therefor I buy. No need to justify a thing. ;)
/ Help me justify a TILLER. #9
I was a little hesitant at first to lay out the money for a tiller, but boy am I glad I did. I till several gardens a year and some were virgin soil. Here in limestone country the tiller hammers on some pretty nasty rocks but it kicks itself off of them or the slip clutch helps out. I use my tiller more than I do my box blade now. I dug out my brother's driveway wider with the tiller, dug out for my above ground pool and dug out for the kids basket ball court. All of these tasks required part of the digging to be at least a foot down, which I had to make a couple of passes. The dirt that I dug up could easily be moved and spread somewhere else as it was smooth and fine. My dad used to do gardens with his double 14 plow and disc and the tiller beat it hands down for QUALITY. The plow and disc are faster, but for smaller sections the tiller is the best, plus you need room to use the disc and plow. My tines are still in great shape after several years of use.
/ Help me justify a TILLER. #11
Tony, I just had an RTS40 Bush Hog tiller (40" wide; tilled 38") that I bought when I had a B7100 Kubota. After the front end loader, it was undoubtedly my most used implement. I had one garden spot that was 83' x 103' where I planted 80' rows 5' apart so I could easily till between the rows even after the crops were firmly established. I know some say you can till too much, but I tilled between the rows when it got dry enough after every rain. And I tilled during the off season to keep grass and weeds from getting established in the garden. I later tilled an additional 15' x 85' garden spot for cantaloupes and melons. I tilled one neighbor's garden pretty regularly and occasionally three others. I was hired to till a fire break around one house that had been vacant awhile. I had no rocks on my place but that clay could make some hard clods that were hard to work with. The tiller would break them up so I could smooth and level areas. I even tilled an old pond dam to loosen it and get rid of clods before pushing the loosened dirt into the dried up pond to fill it in. A tiller was an expensive, but almost indispensable implement as far as I was concerned.
/ Help me justify a TILLER. #12
A 4' tiller in a garden that size will be the best 10 minutes you spend twice a year ;)
I picked up a used LandPride 50" for $400 and put another $150 or so in for new tines. Take the money you would use for a walk behind tiller and find a used 3pt tiller.
As for other uses, I have rehabilitated lawn with it, put in new lawn where we had weeds before. I till up my kids dirtbike track every now and then. The track can be a little hard on it when it is packed down and dry. I am thinking of either getting a small disk or maybe a box blade and use the rippers for the track and save wear and tear on the tiller. I also use it to work over my compost piles, really helps chop stuff up and mix it together.
Since the tiller is pretty compact it is my preferred counterweight for the loader.
Charles
/ Help me justify a TILLER. #14
Look in the local papers and maybe craigs list for the closest people that sell grey market tractors like Yanmars etc. They usually will have rice paddy tillers for 2-400. Around here, the KK 60" gear tiller is $1099 this time of year. About to jump up to $1299 in spring. KK 6 1/2 ' disc's are $799.
For what you are looking at, search the for sale's in the paper and yard sales and buy a $50 24" wide walk behind tiller. Have your wife run it. When 1/4 of the garden is tilled, take her to the farm store and bring home a tiller.
jb
/ Help me justify a TILLER. #15
Hiya,
Too bad your not in snow country....
I was able to justify my shiny new 655 Deere tiller to the other half by ripping up over 250 feet of grass along the driveway with the new Curtis blade I justified by not getting a new snowblower....
Good luck,
Tom
/ Help me justify a TILLER. #16
Here's a strategy. 1st, rent one from Sunbelt rentals. It's a standard item and there are many in your area (closest one seems to be Greenville).
Sunbelt Rentals: Locations
I did this last spring and it was about $50 per day.
After you've done an amazing amount of beautiful tilling, take it back and look for the next opportunity to rent it again. $50 per day adds up pretty quickly and it's not too hard to justify the investement at that point.
Some specific projects/tasks to justify the investment:
  • flower beds.
  • new lawn
  • expand the garden
  • tilling the neighbors garden for $$ or favors.
Good luck :)
/ Help me justify a TILLER. #17
I use a tiller for many landscaping jobs. Latest one was to till a 16' X 40' area for a RV pad. Tilling the area made it very easy to remove sod and put dirt in low areas of our yard. By tilling a second time after removing first 6" gave me the correct depth for putting in fabric and base. MY Kubota dealer sells more tillers to landscapers than gardeners.
/ Help me justify a TILLER. #18
You beat me to it john...! lol
To justify a tiller is simple. If you're strong as an ox then a walk behind tiller will do you fine. If you're like the other 75% of real people with average build, a walk behind tiller will hurt after you're done esp with the area you're talking about. Back, arms, shoulders aching for a few days.
I like the idea of using a middle buster/sub soiler to loosen the soil before using the tractor mounted tiller, sounds like a good plan.
BUY the tractor mounted tiller, You can smile as you are making you're passes, not sweating and cursing the walk-behind as it jumps and bucks.
/ Help me justify a TILLER. #19
I have to agree with purchasing a grey market tiller. They are very inexpensive and can offer very good performance. Around here, used name brand tillers sell for only slightly less than new so the grey market ones are typically 50%-75% less than a good used brand "XYZ". The one caveat is that if you are breaking hard clay etc for the first time, it is best to loosen it with scarifiers or a middle buster. The rice paddy tillers have thinner tines than "conventional" tillers and WILL break more easily. I have had mine for 5 years and use it to put in my garden every year but mostly used it for preparing lawns and blessing my neighbors and friends with tilled garden plots that they wouldn't have been able to have otherwise.
I had a coworker in your same predicament and had a hard time justifying buying one. I found him a used 5' grey market tiller that was in perfect condition for $500 and he paid for it the first spring by putting up flyers and a newspaper ad to till gardens. He established a minimum fee of $50.00 and said he ended up turning down work. There are a lot of people that would love to have a garden but no way to put one in...if you wanted to go that route it is easy to justify the expense by considering it a business investment.
/ Help me justify a TILLER. #20
john_bud
That is great! That explains why you are an Elite Member.
jb[/QUOTE]
