Help me identify this engine
/ Help me identify this engine #1
rszimm
Ford CL65
This engine is in a Ford CL65 Skid Steer. Just figured out that the engine in this unit is likely not the Shibaura U1004 that it originally came with. So what is it? Obviously a 4 cyl diesel. There's a casting mark on the left side of the block that says "S2". There's a serial number stamped into the right side of the block "P11061". Beyond that I can't really see any other identifying marks albeit it's a bit tight in there and hard to see.
Link to albumSkid Steer Engine ID - Album on Imgur
/ Help me identify this engine #3
Perkins diesel engine. The number on the block behind the injection pump will tell you the exact one.
I think there should be a few more numbers there.
Thanks Franklinute. It's actually a Mazda S2 Engine. This was apparently built off a Perkins license and is nearly identical to the Perkins 4.135. It got put in 80s era B2200 trucks and 2.2L Diesel Ford Rangers.
So now I've just got to find a service manual for the Perkins engine or else the 84 ford ranger. I'm hopeful that parts will be far more available than the Shibaura engine that it came with.
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2014 Dodge Grand Caravan Van (A61574)
2014 Dodge Grand...
New/Unused Landhonor No Till Seed Drill (A65583)
New/Unused...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
