Help me figure out how to get factory Kubota 2nd rear remote on MX5200 please (float)
   / Help me figure out how to get factory Kubota 2nd rear remote on MX5200 please (float) #1
MechanicalGuy
Platinum Member
Beautiful South
Kubota mx5200
I'm getting a ton of conflicting info from the threads that I've searched, the dealers that I've talked to, and my research.
The threads and the dealers seem to suggest that I need L8304 & MX8452. I've had that quoted at $253+$244 for a total of $497 + shipping. The dealers could not tell me if all the hoses and quick connects came with this. They described it as L8304 is the valve o-rings and misc small stuff, and the MX8452 is the bolts and washers, lever, knobs,washers, bolts, and manual.
From my research on Messicks incredible website, it looks like all of this will get me were I need to be;
The $40 dollar guess is for the lever. I do not have a quote for that yet.
MX6882
L8304
MX8452
This guy says that the lever is part of the kit on orangetractortalks;
I am fairly new to Kubota even though I have had my MX5200 HST 4WD since new for over 2 years now; I always had Ford tractors prior to this one. I am looking at installing the Land Pride 380-166A 3rd Function kit to my LA1065 loader to be able to run a grapple; I am also looking at installing rear remotes at the same time for plows, a homemade log splitter, a Rhino 12' shredder, and any other hardware that requires rear hydraulics. My first question is with the 3rd Function kit am I limited to 2 rear remotes or can I still install all 3? My second question is for the rear remotes; can anyone confirm if these are the correct parts I need or if I missed something?
1st Rear Remote: L8303 valve / MX8451 mounting base/lever
2nd Rear Remote: L8304 float detent valve / MX8452 mounting base/lever
3rd Rear Remote: L8303 valve / MX8453 mounting base/lever
But it is not present on the Messicks pdf:
I wish I knew what w/g meant. And also why the v62502 number?
So my other local dealer said this will get it:
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
