Help me clarify conflicting information
/ Help me clarify conflicting information #1
easygo
Veteran Member
Maine
Kubota B7800
I'm about to go and get a block heater for my B-7510 and I found conflicting info on the installation here. One post states that a threaded plug comes out and the heater just threads into the block and all I need is teflon tape to seal the threads. Another poster mentions something about draining the radiator to do the installation because a hose is in the way. Has anyone installed their own or seen it done. How easy is it to do the job on the 7510? I just want to know how big of a project I'm looking at.
Easygo
/ Help me clarify conflicting information #2
Both may be correct - on some models the heater threads into a bushing, and the bushing goes into a tapered hole in the engine block.
Here's a thread about my heater. It needed the bushing and was installed in a freeze-plug location.
Maybe your B-7510 engine already has the threaded hole?
Thanks for the reply rbargeron,
The 7510 has a threaded plug that the heater replaces, I was just wondering if the coolant has to be drained completely, or there is a way of getting the heater installed without the draining the coolant.
/ Help me clarify conflicting information #4
You will have to drain the coolant until its level is below the bottom of the plug/heater. Since you can't see inside the radiator or the block, the problem is knowing when you have drained it down to that level. I always drain it completely, then I'm sure. Of course, it's not a really big deal if you don't drain it down enough - it will drain itself out the hole when you remove the plug.:eek:
I installed an aftermarket block heater on my B7800. It is threaded, but it is smaller than the threaded plug in the block, so I had to install a reducer bushing to make it fit. It works great.
/ Help me clarify conflicting information #5
If you are "faster than a speeding bullet" you don't need to drain first. The rest of us do have to drain the coolant. ;)
Coolant drained and heater installed. Thank you for the helpful comments.
had a beer too
/ Help me clarify conflicting information #7
Having installed a block heat in my B2910 without draining the radiator or block and losing less than a cup of antifreeze. Give this a try. Have plug ready for install with tape or thread dope already on it.
With the engine cold (not been run for at least a day. Do not loosen or remove radiator cap. This will take vacuum that is created from antifreeze cooling. Remove the plug (most Kubota plugs are 17mm hex key) Have a bucket setting under hole to catch what little should come out of hole. Install the new plug. Refill radiator for antifreeze that was lost. Job is done.
Longhorn Skull (A65583)
Longhorn Skull...
2011 CLARK OIL FIELD FLOAT (A65643)
2011 CLARK OIL...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
(4) Wheels and Tires for 4-Wheeler (A65579)
(4) Wheels and...
2015 Ford F-250 Ext. Cab Pickup Truck (A64556)
2015 Ford F-250...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
