WildlifeBio
New participant here.  I purchase and manage properties in a growing network of wildlife conservation areas in the Pacific NW.  These properties often come to us with scattered ag fields in various conditions:  active dryland crop lease, enrolled CRP, previously-enrolled and neglected CRP, abandoned hay and pasture fields, etc. (5-100 acres each).  Our goal for these fields, in general, is to convert them back into native cover (to the extent practical).
I'm interested in exploring seeding options for these sites. Our typical initial seed mix consists of native bunchgrasses (mainly Idaho fescue) and short-lived bromes. In past years, we've used conventional methods: chisel plow (when necessary), disc, harrow, broadcast seed, harrow again. If we continue on this route, I'll probably start incorporating a packer roller. But I'd like to shift toward no- or minimum-till methods, and I'd also like the option to seed some native forbs at a later date (using the same equipment, if possible). Being able to rehabilitate smaller patches without taking everything back to bare soil is desirable also.
Here's what I'm basically looking for, at this early stage:
This is new territory for me, so any thoughts or input would be greatly appreciated.
- Ability to plant into prepared ground, dry weed litter, and established bunchgrass stands;
- High-density stands without multiple passes (worried that typical drilled spacing won't result in competitive stands during the first few years (?));
- Native seed box plus options for larger forb seeds;
- 7-10 working width;
- Operable with 82- and 110-HP tractors;
- Pull-type preferred over 3-Pt, depending on the implement.
