Help Making something
   / Help Making something #1
pualsline
so I know this question does not belong in this section but I wasn't sure about where to put it...So here is my question
I have a brick wall that I am wanting to hang a sign on. I don't want to drill holes or anything like that. So I am wondering if I should you some type of adhesive and put hooks at the corner for the sign and if so what type? Is there a better alternative? I am wanting to be able to change out the sign easily...but my primary concern is damage to the wall
   / Help Making something #2
In a similar situation, I "nailed" a small trim board to the wall with those .22 powered hammer nails. Then I put a couple of nails into the board on which I hang my sign with some small hooks. A vice grips is all you need to pull out the "nail" from the brick. I put one in the mortar and one in the brick. When you are done, seal it with some caulking. take an old brick and mash it up into a paste and that will hide the small hole, if that's a concern. Since then, I found you can "nail" gutter downspout straps, tool holder boards, insulation, an other things with this system both into cement and into brick.
   / Help Making something #3
Epoxy putty.. make 2 good size balls of the stuff and stuff them into a mortar joint leaving them a bit prowd.. go ahead and screw your hooks into it and then let setup.. can remove hooks when needed, and with care and a chissle and hammer, remove putty taking little bits at a time..
soundguy
guys thanks so much for the advice. I am going to try and stay away from putting any holes into the brick. The building is not mine, and the owner said that I could hang a sign as long as I am willing to cause zero damage. I like the idea of the epoxy putty and putting the hook into that so that I could just chizzle that away whenever I am done...Are there anymore ideas that we might have overlooked?
   / Help Making something #6
I saw a guy hang a 4x8 plywood sign to the wall of a concrete block building by taking a 2x2 sheet of 1/4 plywwod, cutting it into 4 1x1 pieces and then putting large head roofing nails thru the 1x1 in a few places.. then using about 8 lines or clear rtv across the back of each 1x1 plate and stuck them to the wall so they would match the corners of the sign.. he used a 2x4 wedged against the ground to hold each 1x1 to the wall till the rtv dried ( cured).. then he put the plywood sign up to the backing boards that had some nails sticking straight out.. then nailed it straight on.. the nail heads protruded about 3/8 and he just bent them over... removal was with a crowbar.. just leveraged the main board and smaler boards off.. the rtv stuck in some places but a bit of hand work removed it with no permanent changhe to the block wall except some mildue behind the board where no sun got.. ( seems like alotta work to me.. but worked.. )
soundguy
   / Help Making something #7
Polyurathane caulking (Flextra is one brand) is what sign makers use to install the large letter signes you see on many commercial buildings.
PL3 construction adhesive would also work.
Those signes are often simply foam insulation board cutout letters stuck on the building.
Wire brush is used to remouve the adhesive at later date.
Just helped a buddy sign his commercial building that way.
WE hot wire cut the letters and applied 2 coats of latex to seal and color the letters and stuck them on. Looks good!
   / Help Making something #8
IMO- Glue would be more of an issue to ever have to remove,
why not drill holes? there usually isn't any damage done to a brick wall if you simply drill small holes into the mortar, then use some red heads tap-con type screws or even led set anchors, then if ever you need to remove the sign, remove the screws, there is a mortar caulking (QUIKRETE) that is for the use of filling these holes, comes in most of the common mortar colors and has a % of sand in it just as the mortar has,
The OP has already stated twice, in no uncertain terms, that drilling the wall is 100% totally out of the question... to continue to suggest and push the issue seems pointless???
soundguy
   / Help Making something #9
soundguy
My deepest humble apologies go out to the forum for not reading that it had already been mentioned 1 time before to drill holes, I will retract my suggestion and take my 10 lashes like a man,:(
I only mentioned what I did because I've only installed maybe 2000 sets of shutters and wooden Pediments,pilasters,etc, over windows and doors on brick using the mentioned method and also have removed them as well, But I had a liability concern I couldn't take a chance of one falling off the wall and hitting someone, I don't think I could had gotten by with simply gluing them on,
trust me I'm not pushing the issue though:p
   / Help Making something #10
You said that it's a wall. Is it a wall that has a top to it? Can you hang something over the top of the wall? I'm thinking of a bracket that would to up the wall, over the wall, and then back down the other side for a short distance.
I would make it out of steel. Probably one inch square tubing. If you can't weld, it would be real simple to hire it done. Just know your measurements.
Once built, it would be easy to bolt just about anything to it. If it's a small sign, or something lightweight, you could even use self tapping screws to attach the sign to the metal.
If it's a wall of a building and there isn't a top to it like a wall or fence wolud have, then I'd think along the lines of how painting were hung in old homes. With plaster walls, they hung the paintings from the moulding at the top of the wall. If you can find a wood will, or something that you can screw into, then eye screws and wire would be very strong.
I don't care for glueing anything to brick. It's so porous that it's very hard to get something to stick. Once it adheres to the brick, it will never come off. You will have to take off some of the brick to get rid of it. Compared to the very minimal damage that drilling into morter would cause, glue would be allot worse.
A picture would be very helpful. Seeing what you have to deal with, and know what size and type of sign that you want to display, will allow us to give you a much better reply. Right now, we can only guess as to what you are dealing with.
Eddie
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52748)
3-Point Hitch Root...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
9' Root Rake (A50120)
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52748)
NEW 2022 Load...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
