HELP - Kubota M6040 - HELP
   / HELP - Kubota M6040 - HELP
Hello again, :)
It's not the shuttle, the noise is still there. But it seems to be diminishing.
My dealer is GREAT!
Thanks again, :)
... if you come up with any other possibilities let me know,
I will post, if I find it in this life time .... :D
Thanks, but it's not the shuttle ..... the noise doesn't affect any operation .. I have a loader and a backhoe ... the noise is there, with or
without these attached. Oh Well !?
   / HELP - Kubota M6040 - HELP #13
Tell your dealer to check the oil cooler bypass - the spec is 711 PSI and it needs to be on the number.
The dealer can find this in his service bulletins
Hello & Thanks for your help ....
haven't had any luck finding it so far .....
I have the tractor now so the dealer will have to come here to check this, but I will call tell him about the service bulletin.
In the bulletin does it mention a NOISE, associated with the pressure, 7-11 psi. of the oil cooler bypass.
Thanks Again! :)
Hello Yankee Clipper,
I called the dealer, that was the first thing they did. They replaced the hydraulic oil cooler bypass pressure valve.
   / HELP - Kubota M6040 - HELP #16
I just bought a 2013 Kubota M6040 hydraulic shuttle and it is making the same clunking sound at idle. Did you ever find out what was causing yours. Just brought my tractor to the dealer no word from them yet.
I HAVE CLOSE TO A THOUSAND HOURS .... NO PROBLEMS AT ALL .... I DON'T EVEN NOTICE THE NOISE ANYMORE ... FORGET TO LISTEN ....
MY DEALER CHECKED EVERYTHING - THEN HAD KUBOTA'S TECKS CHECK EVERYTHING .....
HE THEN WENT TO ANOTHER DEALER - AND THIS DEALERS M6040 MADE THE SAME SOUND .... HE THEN ORDER ANOTHER NEW ONE FOR HIS DEALERSHIP AND IT MADE THE SAME NOISE ! I WENT THERE AND HEARD IT.
SO, AS BEST I CAN SURMISE ... IT IS THERE, BUT IT IS NOT A PROBLEM.
   / HELP - Kubota M6040 - HELP #18
My tractor was a harvest lease rental with 300hrs, i bought it two weeks ago as a new tractor. Once i got it home i notice the noise. I had just brought it to the Dealer when i saw your post. Thanks for the reply, you have eased my concerns about this now will wait for dealer response. Thanks again !!!
... MY PLEASURE... I WILL BE CURIOUS AS TO YOUR DEALERS RESPONSE ... ...
   / HELP - Kubota M6040 - HELP #20
Will let you know what they say.
Bomag BW120AD-4 Double Drum Roller (A49461)
Bomag BW120AD-4...
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A51039)
John Deere 6105E...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
