Help: "Knob & Tube" Wiring Problem!
   / Help: "Knob & Tube" Wiring Problem! #1
Dougster
MA
2004 Mahindra 4110 w/509 BH
Hope this post is appropriate for here...
My GF lives in an old 2-family house which still has a small handful of the original "Knob & Tube" electrical circuits still in operation. One of those old circuits feeds her dining room chandelier through a wall switch. Recently, the wall switch stopped working and I was given the assignment of making it work again. But when I opened up the switch's single switch electrical box to replace the switch, I found that a previous repair had been made to lengthen one of the two wires going to the switch with a tiny gauge pigtail and small wire nut. Apparently one of the original two K&T leads going to the box had broken off way toward the back of the box... barely visible now.
The pigtail and wire nut that were used for the repair umpteen years ago is nowhere near adequate for the modern chandelier's current draw. It's amazing there was never a fire. But now the task has fallen to me to lengthen the broken wire in some sane, safe and sensible way. It is far too brittle to try pulling more length out from between the walls... and much too short to get a decent size pigtail and wire nut onto it. Other than maybe soldering and shrink tubing it... does anyone out there know of a safe way to "lengthen" that old, short and very brittle K&T line??? :confused:
Dougster
   / Help: "Knob & Tube" Wiring Problem! #2
My best advice is to learn how to "fish" the walls and replace that wiring. If your not up for the task...hire an electrician. It will be cheap in the long run:D
   / Help: "Knob & Tube" Wiring Problem! #3
There really is no GOOD way to fix what you've described other than re-running the whole wire. If you're lucky, you can attach the new wire to the old wire and use the old wire to pull the new one through the wall.
If re-running the wire seemed like a major project, I might try to use an underground splice kit. You can get them with butt splices that have set screws, and that might allow you to attach a pigtail to the short wire. The splice kits usually come with adhesive lined heat shrink tubing that protect the splice.
I would not try soldering, as it will not make a suitable electrical connection.
It was actually an electrician that made the decision to leave certain of these circuits K&T when the whole place was 95% rewired. Everything he could reasonably replace, he did. This is one of those he couldn't... presumably because of the light circuit extending up into the first floor ceiling (and God only knows where else!!!). :eek:
Of course, I could shoot him today for not trying harder... but that is another story! :D
Dougster
Underground repair kit is a good idea if they make them that small in gauge... worth looking into.
I never knew this before yesterday, but K&T circuits are ALREADY soldered all over the place. It's part of how they built them. Go figure! :rolleyes:
Dougster
   / Help: "Knob & Tube" Wiring Problem! #6
Dougster,
Go here and look for a W30 connector it's on page 4 or 5. If you can get a pair of needle nose on the wire, just slip this on and extend from there. You can also use a P-Nut, do a google search.
Inspector507 said:
Dougster,
Excellent solutions Inspector507!!! Thank you!!! :)
Dougster
   / Help: "Knob & Tube" Wiring Problem! #8
move the box a few inches?
Believe it or not, this K&T wiring comes in from the basement and goes up and over the dining room doorway before splitting and going up to the chandelier and down to the light switch. The switch box would have to be moved upward to gain a little slack... not a pretty or practical solution. :eek:
I think Inspector507 has my solution... essentially a high amperage, solid copper wire crimp or push-on connector. If I can find one or the other at the local electrical supply house, it would be ideal! :)
Dougster
   / Help: "Knob & Tube" Wiring Problem! #10
You are taking the easy way out! :mad:
This project clearly calls for sledge hammer, saws all, trash cans full of plaster and lathe strips, brooms, dust pans, plaster's stilts, etc... where's Tim Taylor when you need him??? :D:D:D
LOT LOCATIONS (A53426)
UNUSED CHERY INDUSTRIAL 10' - 15 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
