Help! JD950 Hydraulic expert. FEL to rockshaft?
   / Help! JD950 Hydraulic expert. FEL to rockshaft? #1
Anonymous Poster
Epic Contributor
I have a JD950(1984) TW drive, no PS, and no hydraulics other than the rockshaft. I have purchased a Koyker 160 FEL. All controls, and hydraulic lines were included up to quick connect connections on pressure and return lines. How do I connect in to the rockshaft block? Do I need additional hydraulic devices? How do I maintain rockshaft hydraulics, and get oil to the FEL? Help! I am apparently living in a hydraulic information Black Hole around here. Thanks.
   / Help! JD950 Hydraulic expert. FEL to rockshaft? #2
There is a divider/valve block on my 1050 for the FEL and the power steering. The 1050 is basicly a turbo'd 950 so I'd bet it's the same for the 950. A shop manual or the dealer's computer would tell you more.
Re: Help! JD950 Hydraulic expert. FEL to rockshaft
Thanks for the info Scott. I've ordered a shop manual. Two of the local JD dealers have tried to help but without much success. I'll keep asking. Thanks again. David
Mini-Excavator Heavy Duty Weed, Brush, and Rock Rake (New/Unused) (A59225)
Mini-Excavator...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
Electric Sweeper W/Pressure Washer, Water Hose, & Mister (New/Unused) (A59225)
Electric Sweeper...
PALLET OF MISC (A58374)
PALLET OF MISC...
2017 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2017 Elgin Broom...
2016 Cat TL1055D Telehandler (A56435)
2016 Cat TL1055D...
