Price Check Help JD / Kubota price comparison. 50 hp non-comp
   / Help JD / Kubota price comparison. 50 hp non-comp #1
jeromet
I am looking for a 50 horse cab tractor / 4x4 w/Fel. In my area it looks like John Deere is a lot more expensive. I am comparing the m4900 kubota at $30,000.
   / Help JD / Kubota price comparison. 50 hp non-comp #2
So if you fill out your profile we will know what area that would be.
Also, what tractor did you compare to the M4900 that came out more expensive? Altough I would point out that there are seldom perfect comparisons. The more expensive tractor is likely to have features or capabilities or less obvious things that make it that way.
Cliff
   / Help JD / Kubota price comparison. 50 hp non-comp #3
I was able to build a nicely equiped 5105 (50 HP), 4WD, w/ 522 FEL for just over $30k ($30,661) on Deere's website. And that's list price. Likely, you can get it for 10% less or better.
Check it out
   / Help JD / Kubota price comparison. 50 hp non-comp #4
Be sure you are comparing apples to apples-some of Deere's competitors have made a lower priced, lower Spec Tractor forcing Deere into the 03 and 05 Series, so check Engines, Hydraulics, Weights, Loader Capacities and so on-sometimes the price you pay IS the price you pay-
HYDRAULIC SKID (A52472)
HYDRAULIC SKID...
2014 Ford Escape (A50323)
2014 Ford Escape...
2013 BOBCAT S630 (A52472)
2013 BOBCAT S630...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
HAY KING RENOVATOR (A52472)
HAY KING RENOVATOR...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
