Help in removing a diesel spill in car backseat
   / Help in removing a diesel spill in car backseat #1
mrmotto
Oregon
Kubota 7610
About a gallon of diesel spilled out of a 5 gallon can onto the cargo area of our Subaru Outback. We were able to wipe up most of the spill but some got into the carpets and the foam of the seats. Anyone know what will help to get the residue and smell out?
   / Help in removing a diesel spill in car backseat #2
Try SIMPLE GREEN to help with the smell.
Don't ask how I know /forums/images/graemlins/blush.gif
Or Read This Thread
   / Help in removing a diesel spill in car backseat #3
Well, diesel smells pretty good as long as it's where it's supposed to be. /forums/images/graemlins/wink.gif Looks like I get to ruin your day too! The only thing I can think of is replace the carpet and seats. /forums/images/graemlins/frown.gif I realize that isn't what you want to hear, hope someone comes up with a better solution for you. /forums/images/graemlins/smirk.gif
   / Help in removing a diesel spill in car backseat #4
Bob, that might be the handiest tip I've ever read on TBN.
Since reading about your ordeal; and the postitive outcome:
I've used it on diesel, grease rags, and just yesterday, found it works pretty good against mineral spirits! /forums/images/graemlins/smile.gif
   / Help in removing a diesel spill in car backseat #5
use Dawn dish washing liquid lemon scent. Remove from vehicle first and use lots of soapy water to break down the oil first. Then rinse well and leave outside to dry. If you get the bulk of it out, then it will eventually dissipate to the atmosphere. The idea is to break down the oil with the dish washing liquid. Cold water will break down the soap. Warm water will help to flush out the oil. If nothing else works, start looking in the salvage yards for a new seat and carpet. Getting it out of the foam is going to be the hardest part. If the car is relatively new, you might be able to order new foam for the seat. Junk......
   / Help in removing a diesel spill in car backseat #6
get an OZONE generator, and run it for 15 munites.
   / Help in removing a diesel spill in car backseat #7
We use a good bit of Simple Green ourselves. I washed a car engine with it this morning.
   / Help in removing a diesel spill in car backseat #8
I have an OZONE generator too, It will remove almost anything. But I would try simple green first.
   / Help in removing a diesel spill in car backseat #9
Diesel spill inside car !! = New car !
Egon /forums/images/graemlins/grin.gif
   / Help in removing a diesel spill in car backseat #10
</font><font color="blue" class="small">( get an OZONE generator, and run it for 15 munites. )</font>
BINGo. I spilled about 2 gallons of home heating oil when I removed my oil tank. Picked up all I could and put the ozone machine, using term losely, (alpine air XL15S) by it and 1 hour later, nothing.
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A55301)
2020 Westfield MKX...
2017 Ford F-750 Altec LR758 58FT Insulated Bucket Truck (A52377)
2017 Ford F-750...
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A55301)
FIRESTONE 9.5L-15...
