Help in Dismounting FEL
   / Help in Dismounting FEL #1
jpat34721
Sonoma County (California Wine Country)
MF 1260
I have recently purchased a used MF1260 with a 1246 FEL, my first tractor. The loader needs some welding/hydraulic work so I want to dismount the loader so I can continue to use the tractor and to make it easier to replace the alternator which also needs to be done. I have the loader operating manual so I am fairly clear on the procedure except the final step:
"If tractor hydraulics were used for loader operation pressure and return couplers on tractor must be connected together to prevent hydraulic system damage and permit operation of three point hitch."
I assume I am using "tractor hydraulics" (how could it be otherwise??). Do I need to purchase some sort of adapter to connect these lines together? If so what do I ask for?
Thanks,
Jeff
   / Help in Dismounting FEL #2
The two lines that connect to the loader valve to the tractor should have two quick connects on it, a male and a female. You uncouple the two sets and recouple them back to each other so the oil can circulate thru the pump back to tank or thru the second circuit if you have one.
If you don't couple them back together you'll blow the pump as it's deadheaded with no pressure relief in the circuit. Mines a Koyker but I would assume it's the same procedure......Mike
WINDLASS 5 HEAD (A53843)
WINDLASS 5 HEAD...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
7 Battery Backup Surge Protector (A51695)
7 Battery Backup...
2007 NLB Trailer Mounted Shell Side System (A53117)
2007 NLB Trailer...
2017 Kubota M5-111D Tractor (A52377)
2017 Kubota...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
